[GRASS-user] python scripting using eclipse
    Ismael Gómez
    gomez.ismael at gmail.com
    Wed Jan 11 11:03:20 EST 2012
Hello everyone,
I would like to run some scripts using python. I am not a computer
scientist/engineer, just a python newbie, but I find that's a really
interesting matter.
Thus, I followed the instructions here:
http://grass.osgeo.org/wiki/Using_Eclipse_to_develop_GRASS_Python_programs
and doing so i was able to run from Eclipse the following simple script
under windows (WinGRASS 6.4RC2):
#!/usr/bin/env python
# MODULE:       model
# AUTHOR(S): ismael
# PURPOSE:      Script generated by wxGUI Graphical Modeler.
# DATE:         Mon Dec 19 18:49:29 2011
import sys
import os
import atexit
import grass.script as grass
def cleanup():
    pass
def main():
    grass.run_command("v.extract --overwrite",
                      input = "parcelas at Modelo1a",
                      output = "parcelasLucrativas",
                      where = "Lucr=1")
    grass.run_command("v.overlay --overwrite",
                      ainput = "fincas at Modelo1a",
                      binput = "parcelasLucrativas",
                      output = "Xik",
                      operator = "and")
    return 0
if __name__ == "__main__":
    options, flags = grass.parser()
    atexit.register(cleanup)
    sys.exit(main())
However, when I try to run it in linux (both Ubuntu 11.10 and Linux Mint 12
installations using the ppa repository) i always get error messages like
the following:
  File
"/home/rosie/Dropbox/REPARCELIA-COMUN/GIS/script/GRASS/Modelo1a/modelo1a.py",
line 40, in <module>
    sys.exit(main())
  File
line 28, in main
    where = "Lucr=1")
  File "/usr/lib/grass64/etc/python/grass/script/core.py", line 176, in
run_command
    ps = start_command(*args, **kwargs)
  File "/usr/lib/grass64/etc/python/grass/script/core.py", line 164, in
start_command
    return Popen(args, **popts)
  File "/usr/lib/grass64/etc/python/grass/script/core.py", line 55, in
__init__
    startupinfo, creationflags)
  File "/usr/lib/python2.6/subprocess.py", line 623, in __init__
    errread, errwrite)
  File "/usr/lib/python2.6/subprocess.py", line 1141, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
Since my knowledge is still very limited, I've spent three days turnning
around it without success.
Could someone give me some hint on where to start to find a solution for
this, please?
Also: when I run it, how/where could I get more information on the
processes running further than those console messages? (sorry, i guess
that's more a Eclipse/Python question than a GRASS one)
Thank you very much in advance.
Regards,
Ismael G.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120111/1dde4277/attachment-0001.html
