[GRASS-user] How to import as vector?
Markus Neteler neteler at osgeo.org
Thu Jan 12 06:18:38 EST 2012
On Thu, Jan 12, 2012 at 6:49 AM, Bulent Arikan <bulent.arikan at gmail.com> wrote:
> Thank you for the suggestions! Yes, it will be a lot of work and time
> consuming to digitize it. I was also suggested to use Inkscape to autotrace
> it and save it in (svg). However, saving it as (svg) does not help because
> 'v.in.ogr' does not seem to import that format. I even saved it as (dxf) but
> the import failed –nothing showed up after importing it as vector layer–
> with 'v.in.ogr' and 'v'in.dxf'.
Perhaps we can get the DXF import fixed? Which types are in the file?
Markus
