[GRASS-user] Re: GRASS 6.4.2 RC3 will not load on Windows 7
Helmut Kudrnovsky hellik at web.de
Sat Jan 14 08:11:58 EST 2012
>>do some paths exist in %PATH% which do not exist
>>in the file system?  (e.g. for addons)
>you are right. I've found it.
>see
>http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/init/init.bat#L29
>%WINGISBASE% for wingrass was recently changed to %GISBASE%, but it wasn't
changed in
>if I change this manually in
>C:\OSGeo4W\apps\grass\grass-6.4.2RC3\etc\Init.bat
>then osgeo4w-GRASS 6.4.2RC3 is starting again.
but I've seen that in the standalone wingrass-installer %WINGISBASE% is
still defined:
C:\Program Files (x86)\GRASS 6.4\etc\env.bat
line 1: set WINGISBASE=%GISBASE%
there seems to be some inconsistency between the wingrass-standalone
installer and osgeo4w-wingrass.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2-RC3-will-not-load-on-Windows-7-tp7183539p7187544.html
Sent from the Grass - Users mailing list archive at Nabble.com.
