[GRASS-user] m.viz.image Command Line
Martin Landa landa.martin at gmail.com
Tue Jan 17 10:43:30 EST 2012
2012/1/17 Martin Landa <landa.martin at gmail.com>:
>> This behaviour should be changed. If you do not define multiple values
>> for given parameters (like `wire_color`) then the module should use
>> default (single) value for all loaded surfaces.
> ops, I overlooked (`-a` flag) see Anna's answer.
btw, I have fixed a bug related to this flag in r50239.
Probably we would not need this flag. From user point of view it would
be probably more understandable eg.
m.nviz.image elevation_map=elevation,roadsmajor out=elev  mode=fine,coarse
would render the first surface in `fine` mode, second in `coarse`
mode. The rest of surface-related options (like `resolution_fine`)
would be used for both surfaces.
Make sense to you?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
