[GRASS-user] m.viz.image Command Line
Anna Kratochvílová kratochanna at gmail.com
Tue Jan 17 12:19:07 EST 2012
On Tue, Jan 17, 2012 at 4:43 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2012/1/17 Martin Landa <landa.martin at gmail.com>:
>>> This behaviour should be changed. If you do not define multiple values
>>> for given parameters (like `wire_color`) then the module should use
>>> default (single) value for all loaded surfaces.
>> ops, I overlooked (`-a` flag) see Anna's answer.
> btw, I have fixed a bug related to this flag in r50239.
> Probably we would not need this flag. From user point of view it would
> be probably more understandable eg.
> m.nviz.image elevation_map=elevation,roadsmajor out=elev  mode=fine,coarse
> would render the first surface in `fine` mode, second in `coarse`
> mode. The rest of surface-related options (like `resolution_fine`)
> would be used for both surfaces.
> Make sense to you?
Definitely, the same problem is with vline_.../vpoint_... params
Anna
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
