[GRASS-user] Import Point from *.csv Problem
Sören Gebbert
soerengebbert at googlemail.com
Tue Jan 24 05:43:15 EST 2012
Hi Johannes,
i guess your csv file uses funny characters for spaces and new lines
and grass can not handle them.
I have attached a screenshot showing the file opened in vim using ubuntu linux.
Best regards
Soeren
2012/1/24 Johannes Radinger <JRadinger at gmx.at>:
> Hello,
> I try to import Points from a comma separated file in GRASS 6.4.2SVN on
> my Mac OS X but somehow I fail...
> The original file is a 3-column Excelsheet (ID,X,Y). I saved that sheet as a *csv in my Excel 2011 on Mac OS X and then I try to import it. I follow the steps in this video (exept that I am working on Mac):http://www.youtube.com/watch?v=JgQBPoJeeLY
> (Tue Jan 24 11:05:42 2012)
> v.in.ascii input=/Users/.../InputForGRASS.csv output=Stations fs=; skip=1 x=2 y=3
> Scanning input for column types...
> Maximum input row length: 31
> Maximum number of columns: 2
> Minimum number of columns: 2
> ERROR: y column number > minimum last column number
> (incorrect field separator?)
> (Tue Jan 24 11:05:42 2012) Command finished (0 sec)
> So I opened the file with textwrangler to check it. I changed the line endings from the original mac endings(CR) to Unix style (LF) and saved the file again, but I get the same error. I don't know what I am doing wrong.
> Even if I copy and paste the coordinates from the text file into the dialog I get the error. I also tried it with G6.5SVN (some weeks old)
> I attached the original *.csv file so maybe someone of you can tell me what is wrong with my import.
> Thanks for your help in advance.
> /johannes
> "Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
> Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit Bin�rdaten wurde abgetrennt...
Dateiname : fancy_csv_file.png
Dateityp : image/png
Dateigr��e : 74051 bytes
Beschreibung: nicht verf�gbar
URL : http://lists.osgeo.org/pipermail/grass-user/attachments/20120124/6d145f95/fancy_csv_file-0001.png
