[GRASS-user] two questions: snap and close lines
Paolo Cavallini
cavallini at faunalia.it
Fri Jan 27 13:04:23 EST 2012
Il 27/01/2012 18:53, Markus Metz ha scritto:
> The only two options I can think of is giving v.edit a try, otherwise
> hand-editing.
Urgh! Too bad, thanks anyway.
> Why does breaking not work? Maybe you need remove duplicates and clean
> small angles at nodes. You could try
> v.clean input=patched at paolo type=line tool=snap,break,rmdupl,rmsa
> thresh=1,0,0,0 output=patched_1
I'm not quite sure break do not work: new nodes are there, but in subsequent steps
they are not treated as closed polygons.
Thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
