[GRASS-user] 6.5svn Crash Report [UPDATE]
Rich Shepard
rshepard at appl-ecosys.com
Fri Jan 27 17:48:25 EST 2012
Just tried to re-import the file. Command window shows:
(Fri Jan 27 14:44:02 2012)
v.in.ogr dsn=/home/rshepard/projects/washington/buckhorn/spatial/Buckhorn_Surface_Water_Stations.shp layer=Buckhorn_Surface_Water_Stations output=Buckhorn_Surface_Water_Stations --overwrite -e -w
Vector map <Buckhorn_Surface_Water_Stations> already exists and will be overwritten
Projection of input dataset and current location appear to match
dbmi: Protocol error
Unable to open database </home/rshepard/grassdata/Washington-SPCS/Buckhorn/dbf/> by driver <dbf>
Unable open database </home/rshepard/grassdata/Washington-SPCS/Buckhorn/dbf/> by driver <dbf>
Unable to find table <Buckhorn_Surface_Water_Stations> linked to vector map <Buckhorn_Surface_Water_Stations>
ERROR: Unable to delete vector map <Buckhorn_Surface_Water_Stations>
(Fri Jan 27 14:44:03 2012) Command finished (0 sec)
Rich
