[GRASS-user] Grass 6.4.2 download
Maris Nartiss maris.gis at gmail.com
Thu Jul 5 03:28:22 PDT 2012
Hello Chad,
I assume You are trying to run it on MS Windows.
Please check following - does Your home folder path contains any
non-latin letters? If yes, try to create a new Windows user i.e.
"grass" and run GRASS from there.
Also worth to check if Your antivirus program / malware defence system
doesn't block GRASS installation (disable antivirus and any Defence+
type system and reinstall GRASS). I have had various strange issues
caused by Comodo AV when installing GRASS or QGIS. Best way - disable
for a moment Comodo AV and Defence+, run install as Administrator,
enable AV back.
Report more information if none of this helps.
Maris.
2012/7/5 Chad Oliver <ccoliver76 at gmail.com>:
> Hi,
> My name is Chad, and I'm completely new to Grass.  I'm not sure if this is
> the forum to ask beginner's questions, but I'll give it a go.
> I'm having trouble downloading Grass 6.4.2 on my home computer.  I've
> downloaded it on all of our work computers without any problems (including
> Windows Vista, XP), but it's not working on my home computer.
> When I double click on the desktop icon, or try to open it directly from
> program files, a window flashes up for a split second and disappears.
> When I go to 'Grass 6.4.2 Command Line' I get the following:
> 'g.dirseps' is not recognized as an internal or external command, operable
> program or batch file.
> 'C:\GRASS\etc\winlocale' is not recognized as an internal or external
> command, operable program or batch file.
> 'g.gisenv' is not recognized as an internal or external command, operable
> 'C:\GRASS\etc\set_data' is not recognized as an internal or external
> 'C:\GRASS\etc\echo' is not recognized as an internal or external command,
> Can anybody help?
> Chad
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
