[GRASS-user] problem with grass 6.4.0
Pierre Roudier pierre.roudier at gmail.com
Wed Jul 11 20:45:44 PDT 2012
Alberto,
Your field separator is set to empty string (fs=""), wouldn't that be
the problem?
Cheers,
P_
2012/7/11 Alberto Pettazzi <alberto.pettazzi at meteogalicia.es>:
> Dear all,
> I was using GRASS version 6.3.0 and everything worked fine.  Now I installed
> 6.4.1 on a brand new server and I am experiencing some problems.
> I want to run the scripts and the locations I had on the old grass and when
> I execute the command on the new version
> r.in.xyz i=input_file.txt o=output_file fs=' ' --o
> this is what I get
> Reading data ...
> ERROR: Bad y-coordinate line 1 column 2. <>
> the file I am trying to read from has the following structure
>    -7.830    43.050     0.000
>    -6.930    42.470     0.000
>    -8.530    42.280     0.000
>    -7.640    41.710     0.000
>    -7.790    43.050     0.000
>    -6.900    42.470     0.000
> and if I run the same r.in.xyz command in the old server I can import the
> file correctly.
> Why????
> Alberto Pettazzi
> MeteoGalicia - Departamento de Climatología y Observación
> Consellería de Medio Ambiente, Territorio e Infraestruturas
> Rúa de Roma, 6
> 15707 Santiago de Compostela. A Coruña
> Teléfono: +34-881-999646
> e-mail: alberto.pettazzi at meteogalicia.es
> <mailto:alberto.pettazzi at meteogalicia.es>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Scientist
Landcare Research, New Zealand
