[GRASS-user] problem with grass 6.4.0
Alberto Pettazzi
alberto.pettazzi at meteogalicia.es
Wed Jul 11 23:45:42 PDT 2012
Hello Pierre,
the field separator is set to a blank space. Using the 6.3.0 version
installed in the old server, r.in.xyz was able to read the file
properly, but with the 6.4.1 version installed in the new server i am
not able anymore...
I also have problems with gdal, that does not read correctly some files,
ie it reads them upside-down...but I will be more specific about that
later on....:)
I wonder if all this mess is due to some fault in the installation process
regards,
El 12/07/12 05:45, Pierre Roudier escribió:
> Alberto,
> Your field separator is set to empty string (fs=""), wouldn't that be
> the problem?
> Cheers,
> P_
> 2012/7/11 Alberto Pettazzi <alberto.pettazzi at meteogalicia.es>:
>> Dear all,
>> I was using GRASS version 6.3.0 and everything worked fine. Now I installed
>> 6.4.1 on a brand new server and I am experiencing some problems.
>> I want to run the scripts and the locations I had on the old grass and when
>> I execute the command on the new version
>> r.in.xyz i=input_file.txt o=output_file fs=' ' --o
>> this is what I get
>> Reading data ...
>> ERROR: Bad y-coordinate line 1 column 2. <>
>> the file I am trying to read from has the following structure
>> -7.830 43.050 0.000
>> -6.930 42.470 0.000
>> -8.530 42.280 0.000
>> -7.640 41.710 0.000
>> -7.790 43.050 0.000
>> -6.900 42.470 0.000
>> and if I run the same r.in.xyz command in the old server I can import the
>> file correctly.
>> Why????
>> Alberto Pettazzi
>> MeteoGalicia - Departamento de Climatología y Observación
>> Consellería de Medio Ambiente, Territorio e Infraestruturas
>> Rúa de Roma, 6
>> 15707 Santiago de Compostela. A Coruña
>> Teléfono: +34-881-999646
>> e-mail: alberto.pettazzi at meteogalicia.es
>> <mailto:alberto.pettazzi at meteogalicia.es>
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Alberto Pettazzi
Rúa de Roma, 6
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120712/9f6ed188/attachment-0001.html>
