[GRASS-user] sqlite-db broken?
Johannes Radinger
JRadinger at gmx.at
Mon Jul 16 05:14:48 PDT 2012
Hi again,
I did another test now and found out following:
It seems that the problem with the sqlite database
might be related to the directory of my grass location.
When I try my to save the location on my local drive
everything works, there is just a problem when
my location points to a directory which is actually a mounted
samba network drive (mount cifs).
Here an output of the directory which is actually a network drive:
radinger at grassgis:~$ ls -la /home/radinger/U_Radinger/05_GRASS/GRASS_locations/
total 0
drwxrwxrwx 5 radinger radinger 0 Jul 16 12:01 .
drwxrwxrwx 6 radinger radinger 0 Jul 13 14:09 ..
drwxrwxrwx 4 radinger radinger 0 Jul 16 11:43 xxx
drwxrwxrwx 4 radinger radinger 0 Jan 26 2009 gisdemo_ncspm
drwxrwxrwx 4 radinger radinger 0 Jul 12 14:16 spearfish60
drwxrwxrwx 3 radinger radinger 0 Jul 16 10:44 xxx
and:
radinger at grassgis:~$ ls -la /home/radinger/U_Radinger/05_GRASS/GRASS_locations/gisdemo_ncspm/sqlite/
total 6
drwxrwxrwx 3 radinger radinger 0 Jul 16 13:15 .
drwxrwxrwx 4 radinger radinger 0 Jan 26 2009 ..
-rwxrwxrwx 1 radinger radinger 24 Jul 16 12:08 .bash_history
-rwxrwxrwx 1 radinger radinger 556 Jul 16 12:03 .bashrc
-rwxrwxrwx 0 radinger radinger 512 Jul 16 12:04 cifs2e55
-rwxrwxrwx 1 radinger radinger 0 Jul 16 12:03 sqlite.db
drwxrwxrwx 2 radinger radinger 0 Jul 16 12:02 .tmp
-rwxrwxrwx 1 radinger radinger 74 Nov 3 2008 VAR
drwxrwxrwx 1 radinger radinger 0 Nov 3 2008 vector
-rwxrwxrwx 1 radinger radinger 361 Nov 3 2008 WIND
Does anyone know hat causes the problem exactly and what should I change?
The db-connection is set to $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db (checked in the VAR file as well)
Maybe the GRASS can't tranlate from the relative path to a hardcoded one when the $GISDBASE is already located on a mounted network drive?
/Johannes
-------- Original-Nachricht --------
> Datum: Mon, 16 Jul 2012 12:04:40 +0200
> Von: "Johannes Radinger" <JRadinger at gmx.at>
> An: grass-user at lists.osgeo.org
> Betreff: [GRASS-user] sqlite-db broken?
> Hi,
> I used to use db.test (with test=test1) to test my sqlite database
> connection. In the most recent verson of GRASS 6.4.3 (rev 52380) it seems to be
> broken. I tried it on some of my own databases and a freshly downloaded
> sample dataset (small NC dataset, mapset=sqlite). I started it from the gui but
> it just get stucked in the process (no output after several
> minutes)...stopping it leaves the database in an incosistent state.
> Thats why I tried just to simply copy a vector file (e.g streams) from
> PERMANENT to sqlite. Then I get the error message: Unable to open header file
> of vector <streams at sqlite> Unable to read head file....
> Somehow working with sqlite doesn't work properly on my machine (Ubuntu
> 12.04) although I the command sqlite3 in the terminal works....
> I also tried it with 6.5 SVN (rev. 52380) and a fresh NC dataset again:
> db.test just gives: Busy SQLITE db, already waiting for 10 seconds...
> What else do I need to test so that someone of you might know the problem
> of my basic database functions (creating tables eg. when tranforming from
> raster to vector etc.)? Can anyone reproduce this or is it just a behavior
> due to my own compilation (configured with sqlite3 support)?
> /Johannes
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
