[GRASS-user] Using i.atcorr on SPOT4 and SPOT5 imagery
Markus Neteler neteler at osgeo.org
Tue Jul 17 15:12:15 PDT 2012
Hi Cody,
On Thu, Jul 5, 2012 at 8:27 PM, Cody Schank <codyschank at gmail.com> wrote:
> One other thing.  For the input range, is it necessary to put the actual
> range of the input radiance values (range usually about 0 to 150).  If I
> leave it as 0,255 I get different output values.  Just want to clarifiy the
> significance of that input field.
You mean:
iscl=min,max
    Input imagery range [0,255]
    Default: 0,255
Honestly I don't know - In the source code I see:
    struct Option *iscl;    /* input data is scaled to this range */
Perhaps internally the command wants to see the image scaled to 8bit?
Anyone having an idea?
Markus
