[GRASS-user] High Resolution ppm
ALT SHN i.geografica at alt-shn.org
Thu Jul 19 04:43:01 PDT 2012
Thank you Hamish!
I just added NetPBM to the %PATH% and now it works.
Thanks a lot!
Cheers
André Mano
2012/7/19 Hamish <hamish_b at yahoo.com>
> André wrote:
> > Thank you for your hints, however I didn't managed to solve the problem.
> > I installed NetPBM tools has you suggested, however I still get hundreds
> > of .ppm files instead of one big high resolution file like I need.
> the programs need to be in the system search %PATH% so that GRASS can
> find them.
> > I then tried Windows command prompt with these sentences:
> > C:\Program Files (x86)\GnuWin32\bin>pnmcat -lr
> C:\Users\Andre\Pictures\aaa\E-W-45_1_1.ppm
> > C:\Program Files (x86)\GnuWin32\bin>pnmcat -tb
> > In both cases all I get has output can be seen in attachment, but no
> > assembled image is produced. What am I doing wrong?
> unfortunately the help page doesn't note that it sends the image to
> stdout. what you're seeing is what you'd see if you tried to open the
> image in a text editor.
> NAME
>        pnmcat - concatenate portable anymaps
> SYNOPSIS
>        pnmcat [-white|-black] -leftright|-lr [-jtop|-jbottom] pnmfile
> pnmfile ...
>        pnmcat [-white|-black] -topbottom|-tb [-jleft|-jright] pnmfile
> pnmfile ...
> so to use it you have to use ">" redirections. for example:
>   pnmcat -lr img11.ppm img12.ppm img13.ppm img14.ppm > row1.ppm
>   pnmcat -lr img21.ppm img22.ppm img23.ppm img24.ppm > row2.ppm
>   pnmcat -lr img31.ppm img32.ppm img33.ppm img34.ppm > row2.ppm
>   pnmcat -tb row1.ppm row2.ppm row3.ppm > final_image.ppm
Associação Leonel Trindade
SOCIEDADE DE HISTÓRIA NATURAL
Apartado 25 2564-909 Torres Vedras Portugal
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
do Ameal 2565-641 Ramalhal
http://alt-shn.blogspot.com
www.alt-shn.org
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120719/eb931d8a/attachment.html>
