[GRASS-user] How we can pickup catagory, lat, long of a point by mouse click event with reference to a vector point map
Hamish hamish_b at yahoo.com
Thu Jul 19 01:43:49 PDT 2012
please reply to the whole list; others here know the vector, gui, db, and ms windows
side of things much better than I do, and other readers might learn from finding
the thread in the archives.
note that changing the attribute table does not change the geometry in GRASS.
for actually moving the point spatially you might try a tool like v.edit.
regards,
Hamish
--- On Wed, 7/18/12, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
Subject: Re: [GRASS-user] How we can pickup catagory, lat, long of a point by mouse click event with reference to a vector point map
To: "Hamish" <hamish_b at yahoo.com>
Date: Wednesday, July 18, 2012, 6:11 AM
Dear Hamish,
  I am developer not user I would like to edit the window like-           And in this case want to shift the point with catagory 110 by changing latDD_1, longDD_1 as user specify the new position. I am unable to do this because I could't find the source code relating to "Update Attribute" Please give me a technical reference.
Thanks & Regards,
Swapan
On Wed, Jul 18, 2012 at 5:29 PM, Hamish <hamish_b at yahoo.com> wrote:
Swapan wrote:
> Yes I have lat long column but I would like to pickup these value to a
> text file by single click event. How I can do it.
if using the UNIX xmons (not the wxGUI), you can use 'd.what.vect -x' and
-t for that. If using the wxGUI you have to cut and paste the results of
the query tool out of the output tab in the layer manager. (select + right
click in the text canvas)
Hamish
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120719/133c3c51/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120719/133c3c51/attachment-0001.png>
