[GRASS-user] Compilation of GRASS 6.4.2 from svn on Ubuntu 10.04
Rebecca Bennett rabennett at ymail.com
Fri Jun 8 07:00:36 PDT 2012
Thanks for your response.
No apparently the configure did not complete without error,as I got
checking whether to use Tcl/Tk... yes
checking for location of Tcl/Tk includes...
checking for tcl.h... no
configure: error: *** Unable to locate Tcl includes.
So that explains why the make won't run. Here is the configure command I'm trying to use (which probably isn't perfect it was just culled of the instructions site)
--with-sqlite --with-cairo --with-freetype --with-cxx --with-geos=usr/bin/geos-config --with-gdal=/usr/bin/gdal-config --with-python=/usr/bin/python-config --with-wxwidgets=/usr/bin/wx-config --enable-largefile --with-proj-share=/usr/share/proj/
full output in text file attached.
Cheers!
Rebecca
>________________________________
> From: nikos ves <vesnikos at gmail.com>
>To: Rebecca Bennett <rabennett at ymail.com>
>Cc: GRASS user List <grass-user at lists.osgeo.org>
>Sent: Friday, 8 June 2012, 14:32
>Subject: Re: [GRASS-user] Compilation of GRASS 6.4.2 from svn on Ubuntu 10.04
>Hey Rebecca,
>Does the ./configure prior issuing the make command ends successfully?
>Nick Ves
>On Fri, 2012-06-08 at 14:17 +0100, Rebecca Bennett wrote:
>> Hello all
>> Trying to update my GRASS installation from the svn to 6.4.2 on Ubuntu
>> Lynx using these instructions
>> http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu
>> Having worked through all the dependencies I get as far as
>>     make -j2 && sudo make install && sudo ldconfig
>> and get the following error
>>     make: *** No rule to make target `include/Make/Platform.make'.
>> Stop.
>> I'm not very good at this so any ideas most welcome!
>> best wishes,
>> Rebecca
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120608/fd232559/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120608/fd232559/attachment-0001.obj>
