[GRASS-user] Compilation of GRASS 6.4.2 from svn on Ubuntu 10.04
nikos ves
vesnikos at gmail.com
Fri Jun 8 07:17:16 PDT 2012
Dear Rebecca,
Since you're on ubuntu I suggest downloading a pre-compiled binary for
grass ready for use for your distribution (unless you want grass to be
able to handle something more exotic):
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install grass grass-dev
Regards,
Nick Ves
On Fri, 2012-06-08 at 15:00 +0100, Rebecca Bennett wrote:
> Thanks for your response.
> No apparently the configure did not complete without error, as I got
> checking whether to use Tcl/Tk... yes
> checking for location of Tcl/Tk includes...
> checking for tcl.h... no
> configure: error: *** Unable to locate Tcl includes.
> So that explains why the make won't run. Here is the configure command
> I'm trying to use (which probably isn't perfect it was just culled of
> the instructions site)
> --with-sqlite --with-cairo --with-freetype --with-cxx
> --with-geos=usr/bin/geos-config --with-gdal=/usr/bin/gdal-config
> --with-python=/usr/bin/python-config
> --with-wxwidgets=/usr/bin/wx-config --enable-largefile
> --with-proj-share=/usr/share/proj/
> full output in text file attached.
> Cheers!
> Rebecca
> ______________________________________________________________
> From: nikos ves <vesnikos at gmail.com>
> To: Rebecca Bennett <rabennett at ymail.com>
> Cc: GRASS user List <grass-user at lists.osgeo.org>
> Sent: Friday, 8 June 2012, 14:32
> Subject: Re: [GRASS-user] Compilation of GRASS 6.4.2 from svn
> on Ubuntu 10.04
> Hey Rebecca,
> Does the ./configure prior issuing the make command ends
> successfully?
> Nick Ves
> On Fri, 2012-06-08 at 14:17 +0100, Rebecca Bennett wrote:
> > Hello all
> > Trying to update my GRASS installation from the svn to 6.4.2
> on Ubuntu
> > Lynx using these instructions
> > http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu
> > Having worked through all the dependencies I get as far as
> > make -j2 && sudo make install && sudo ldconfig
> > and get the following error
> > make: *** No rule to make target
> `include/Make/Platform.make'.
> > Stop.
> > I'm not very good at this so any ideas most welcome!
> > best wishes,
> > Rebecca
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
