[GRASS-user] Personalised raster alghoritm (simple: area)
Daniel Lee
lee at isi-solutions.org
Tue Jun 12 00:37:55 PDT 2012
Hi Antonello,
I would first make a field for the area in the vector attribute table with
v.db.addcol, then compute the area of each vector with v.to.db and store it
in the attribute table. Then I'd convert the vectors to rasters using the
parameter "use=attr" and tell GRASS to use the area column as the cell
values. Hope that helps!
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
2012/6/12 Antonello Lobianco <antonello at lobianco.org>
> Hello everybody on the list!
> I am a "occasional" grass gis user and I'm stuck with a relatively
> simple task: I have a high-res vector layer describing only one category
> (Corine Land Cover map for "broad-leaved forests", 311) and I want to
> rasterise it in a low-res 8-by-8 km raster map where the value stored on
> each cell is the area (or, that's the same, the share of the area) that the
> vector cover within that cell.
> So each pixel/cell would have a value ranging from 0 (no broad-leaved
> forest at all) to 64 (all the area of the pixel is covered by
> broaded-leaved forests).
> I already managed to get the region with the right cell dimension, add the
> area geometry to the vector and load it in grass, but I don't know now how
> to rasterize it (v.to.raster seems to me to not offer the option to put the
> area, but only a specific catgegory, but maybe I am wrong??).
> Thank you for any hint you could provide me.
> Antonello
> Antonello Lobianco
> INRA, Laboratoire d'Economie Forestière
> 14 Rue Girardet - 54000 Nancy, France
> Tel: +33.652392310
> Email: antonello.lobianco at nancy-engref.inra.fr
> http://antonello.lobianco.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120612/b9f25007/attachment.html>
