[GRASS-user] calculate mode value on moving window (with mapalgebra) with null value cells
    Marcello Gorini
    gorini at gmail.com
    Tue Jun 19 03:37:46 PDT 2012
G. Allegri wrote:
I need to assign values to a the cells on the "border" of a raster. The
> inside and the outside are distinguished by having or not having null
> values assigned.
> I also need to keep the other cell values (internals) untouched.
 Hey,
Check out r.grow. I am pretty sure you can modify the example given in the
manual to find the borders of your raster. Something like:
# creates an inverted raster from your raster
> r.mapcalc "raster_inverted=if(isnull(raster,1,null())"
# grow this inverted raster by one cell
> r.grow in=raster_inverted out=raster_inverted_grown
# now both rasters overlap at the border, so you can do whatever you want
with it, for instance, extract it
> r.mapcalc "border=if(raster_inverted_grown==1 &&
isnull(raster)==0,raster,null())"
Hope it helps.
Cheers,
Marcello.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120619/10024e92/attachment.html>
