[GRASS-user] calculate mode value on moving window (with mapalgebra) with null value cells
G. Allegri
giohappy at gmail.com
Tue Jun 19 03:39:37 PDT 2012
Hi Marcello,
thanks, but my problem is not finding the border. I already have it (with
its own category) but assigning it the value from the surrounding (not
null) value, e.g. max/min/etc.
The problem with kernel filters/moving windows is that they do not filter
out null values...
giovanni
2012/6/19 Marcello Gorini <gorini at gmail.com>
> G. Allegri wrote:
> I need to assign values to a the cells on the "border" of a raster. The
>> inside and the outside are distinguished by having or not having null
>> values assigned.
>> I also need to keep the other cell values (internals) untouched.
> Hey,
> Check out r.grow. I am pretty sure you can modify the example given in the
> manual to find the borders of your raster. Something like:
> # creates an inverted raster from your raster
> > r.mapcalc "raster_inverted=if(isnull(raster,1,null())"
> # grow this inverted raster by one cell
> > r.grow in=raster_inverted out=raster_inverted_grown
> # now both rasters overlap at the border, so you can do whatever you want
> with it, for instance, extract it
> > r.mapcalc "border=if(raster_inverted_grown==1 &&
> isnull(raster)==0,raster,null())"
> Hope it helps.
> Cheers,
> Marcello.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120619/b9acd634/attachment.html>
