[GRASS-user] landsat import with python-script
rasmus borgstrøm
rb at gras.ku.dk
Thu Jun 21 22:12:04 PDT 2012
Hi Stefan
Thanks for your response. I am trying to achieve this on a windows 7 64 bit
platform, with GRASS GIS 6.4.2RC2. The syntax must then be different...The
"grass shell" is that the grass gis command line window?
What prerequisites are needed for the location of the scripts and the data?
Need to be in the same folder?
Rasmus
Hi Rasmus,
could you please post that on the forum? I think it is better to discuss
these issues in the forum so others can participate and also learn from it.
I have no experiences using python scripts on the grass gui, so far I only
used it from the grass shell, e.g. like this:
./import_landsat.py 129_048_20060228_LS5
assuming you are working on Linux and '129_048_20060228_LS5' is the folder
where the landsat TIF-files and metadata is stored. Like this you could
easily create a loop and process all your folders at once.
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/landsat-import-with-python-script-tp4366043p4983130.html
Sent from the Grass - Users mailing list archive at Nabble.com.
