[GRASS-user] access vertices coordinates of a line from Python
    gene
    martin.laloux at gmail.com
    Tue Jun 26 11:34:12 PDT 2012
In fact, you can also use OGR python bindings, it is easy
     from osgeo import ogr
      # open grass vector
     ds = ogr.Open('/grassdata/geol/test/vector/linevector/head')
     layer = ds.GetLayer(0)
     layer.GetName()
     'linevector'
     feat = layer.GetFeature(0)
     geom = feature.GetGeometryRef()
     geom.ExportToWkt()
     'LINESTRING (206643.21517600651714
125181.180585758760571,201007.334329231875017
121517.855520597659051,208615.775875667924993
118699.916871574707329,199034.77765774706495
115036.59058768954128,200725.543214922072366
111936.85601020231843,192835.30987687263405
107428.147941565141082,192835.30987687263405 107428.147941565141082)'
     for i in range(geometry.GetPointCount()):
          xy = geometry.GetPoint(i)
          print xy
      (206643.21517600652, 125181.18058575876, 0.0)
      (201007.33432923188, 121517.85552059766, 0.0)
      (208615.77587566792, 118699.91687157471, 0.0)
      (199034.77765774706, 115036.59058768954, 0.0)
      (200725.54321492207, 111936.85601020232, 0.0)
      (192835.30987687263, 107428.14794156514, 0.0)
After that you can use other modules like *shapely*
      from shapely.wkt import loads
      line =loads(geometry.ExportToWkt())
      list(line.coords)
       [(206643.21517600652, 125181.18058575876), (201007.33432923188,
121517.85552059766), (208615.77587566792, 118699.91687157471),
(199034.77765774706, 115036.59058768954), (200725.54321492207,
111936.85601020232), (192835.30987687263, 107428.14794156514),
(192835.30987687263, 107428.14794156514)]
View this message in context: http://osgeo-org.1560.n6.nabble.com/access-vertices-coordinates-of-a-line-from-Python-tp4983417p4984036.html
Sent from the Grass - Users mailing list archive at Nabble.com.
