[GRASS-user] Get non-NULL cells over multiple rasters
Johannes Radinger
JRadinger at gmx.at
Thu Mar 1 10:01:11 EST 2012
Hi again...
-------- Original-Nachricht --------
> Datum: Thu, 01 Mar 2012 15:18:24 +0100
> Von: Moritz Lennert <mlennert at club.worldonline.be>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Get non-NULL cells over multiple rasters
> Johannes Radinger wrote:
> > Hi,
> >> Datum: Thu, 01 Mar 2012 13:18:30 +0100
> >> Von: Moritz Lennert<mlennert at club.worldonline.be>
> >> An: Johannes Radinger<JRadinger at gmx.at>
> >> CC: GRASS user list<grass-user at lists.osgeo.org>
> >>> Hi,
> >>> I have a bunch of raster maps (~50 are named crast_* and 50 are named
> >>> rast_*). Is there a simple way (eg. using regular expressions) to
> >>> process them with the mapcalculator to get one resulting map which
> >>> shows only those cells (value 1) which are non-NULL cell in ALL maps?
> >>> Like I'd like the cells which all rasters have commonly populated.
> >>> Maybe there is a simple way to do this in the mapcalculator (or any
> >>> other modul) resp. in a python script?? Suggestions are mostly
> >>> welcome. Thanks,
> >> r.series with the -n flag ? From the man page:
> >> "With -n flag, any cell for which any of the corresponding input cells
> >> are NULL is automatically set to NULL (NULL propagation). The aggregate
> >> function is not called, so all methods behave this way with respect to
> >> the -n flag."
> >> See the man page for examples of how to use r.series in conjunction
> with
> >> g.mlist to work with a series of maps.
> > Thank you very much, r.series is the right tool for my task. I tried to
> > use it in combination with g.mlist but somehow I don't manage it. I
> tried different methods e.g.:
> > 1) in the GRASS command console I typed:
> > r.series -n input="'g.mlist pattern='rast_*|crast_*' sep=,'"
> output=Treene_tmp_mask method=count
> Are you talking about the wxGUI command console, or the terminal ?
I was trying it with the wxGUI command console, but I now I'll focus
on the python script...
> In the terminal the whole g.mlist part has to be in backticks (`) which
> means "replace everything which is within the backticks with the results
> of that command". I imagine that this does not work in the GUI command
> console.
> In the terminal your command should be:
> r.series -n input=`g.mlist pattern="rast_*|crast_*" sep=,`
> > 2) and I tried it in a python script with:
> > grass.run_command("r.series",
> > input = "'g.mlist pattern='rast_*|crast_*|Treene_raster' sep=,'",
> > overwrite=True,
> > flags = "n",
> > output = "Treene_tmp_mask",
> > method = "count")
> If you want to work in a python script, you have to first run
> read_command(g.mlist), put the result in a comma-seperated string which
> you then feed into r.series. There are possibly other ways that I don't
> know about...
I followed your suggestions and tried to split the command up into a part
with read_command(g.mlist) and a part with grass.run_command("r.series"). This nearly works, there is just one problem with the read_command(g.mlist). It seems that the output after the last listed map includes a linebreak or something similar. Thus using the output of read_command causes a problem when r.series tries to load the last map.
I made a reproducable script for the spearfish dataset:
#!/usr/bin/env python
import sys
import grass.script as grass
import grass.script.setup as gsetup
def main():
gmlist = grass.read_command("g.mlist",
pattern = "soils.*",
sep=",")
print gmlist
input = gmlist,
overwrite=True,
flags = "n",
output = "test_output",
method = "count")
return 0
if __name__ == "__main__":
sys.exit(main())
cheers,
/johannes
> Moritz
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
