[GRASS-user] Get non-NULL cells over multiple rasters
Glynn Clements
glynn at gclements.plus.com
Thu Mar 1 11:59:30 EST 2012
Moritz Lennert wrote:
> If you want to work in a python script, you have to first run
> read_command(g.mlist),
You can use mlist_grouped(), but it currently only works with glob
patterns, not regexps. Alternatively, you can use list_grouped,
list_pairs or list_strings and manually filter the result. E.g.:
import grass.script as grass
maps = [map
for map in grass.list_strings('rast')
if map.startswith('rast_') or map.startswith('crast_')]
maps = ','.join(maps)
grass.run_command("r.series", input = maps, ...)
