[GRASS-user] How one can find the starting and end point of a line in a vector file or how one can connect two line end to end using C code
ivan marchesini ivan.marchesini at gmail.com
Sat Mar 3 04:14:37 EST 2012
don't know if can help but v.to.db give you coordinates of starting and
ending points of vector lines
to connect them I use v.edit
this is my pythin code
    startc=grass.read_command("v.to.db", flags="p", map="myline",
type="line", option="start", units="meters" , quiet=True)
    startx=float(startc.split("|")[1])
    starty=float(startc.split("|")[2])
    startz=float(startc.split("|")[3])
    endc=grass.read_command("v.to.db", flags="p", map="myline",
type="line", option="end", units="meters")
    endx=float(endc.split("|")[1])
    endy=float(endc.split("|")[2])
    endz=float(endc.split("|")[3])
    tmpfile = grass.tempfile()
    pfile = open(tmpfile, 'w')
    print>> pfile, "L", "2", "1"
    print>> pfile, startx, starty, startz
    print>> pfile, endx, endy, endz
    print>> pfile, "1", i
    pfile.close()
    grass.run_command("v.edit", input=tmpfile, flags="n", tool="add",
map="mynewline", snap="node", thresh="1")
hope this help
Ivan
Il giorno sab, 03/03/2012 alle 11.24 +0530, SWAPAN GHOSH ha scritto:
> Hello,
> Any one can solve me the problem like-" How one can find the starting
> line end to end using C code". If there is any change needed in code
> like C or  Python Script please suggest me. How I can do it.
> Regards,
> Swapan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: ivan.marchesini at irpi.cnr.it
fax (mailfax): +39 1782092534
jabber: geoivan73 at jabber.org
skype: geoivan73
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20120303/af4d5b97/attachment.bin
