[GRASS-user] Possible bug in r.sum and in r.stats?
Rainer M Krug r.m.krug at gmail.com
Fri Mar 9 03:33:30 EST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 09/03/12 00:16, Glynn Clements wrote:
> Rainer M Krug wrote:
>> As some commands do use the region and mask, while others don't, it might be a good idea to
>> make this clear in the manual - I know, it is stated if they do, but not if they don't.
> I would expect it to be the other way around.
I might remember reading in the manual of a module that it uses the region and MASK - but in
general it might be the other way round.
> Most raster modules respect the current region and mask, because it happens automatically.
So the default behaviour is: all r. modules respect the region and MASK, with some exceptions.
> Modules which don't want to use the current region have to explicitly set the working region
> (typically based upon an input map); modules which don't want inputs to be masked have to
> explicitly disable masking.
Makes sense.
> As a general guideline, you should expect any module which actually processes raster data to
> honour the current region and mask (r.info isn't such a module; it just display's the map's
> metadata).
Based on what you say, I think it might be a good idea to
a) state this on the manual page about the raster modules, and
b) separate the list of raster modules into the ones which
  - respect region and MASK
  - respect region only
  - respect MASK only (I don't thik there are any)
  - use the region of the map and don't use MASK
I think this would clarify things a lot.
Cheers,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk9ZwFoACgkQoYgNqgF2egr4jACfad9tQFKGhHeUKDwrhWLhzaAQ
raAAn1yv3Uu2PzgD+hjDRWAIZgSskPm2
=VNgR
-----END PGP SIGNATURE-----
