[GRASS-user] Re: Possible bug in r.sum and in r.stats?
Rainer M Krug r.m.krug at gmail.com
Fri Mar 9 03:39:08 EST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 09/03/12 09:05, Hermann Peifer wrote:
> On 09/03/2012 00:16, Glynn Clements wrote:
>> I would expect it to be the other way around. Most raster modules respect the current region
>> and mask, because it happens automatically. Modules which don't want to use the current
>> region have to explicitly set the working region (typically based upon an input map);
>> modules which don't want inputs to be masked have to explicitly disable masking.
> Just a thought, not sure if it really makes sense: Raster modules that ignore the current
> region and/or mask could issue some sort of warning, in analogy to "[Raster MASK present]"
> which comes up all the time if I have a MASK map somewhere in the visible mapsets.
I think that's a good idea - something along the lines of:
"[region ignored for this command]"
and
"[MASK ignored for this command]"
Rainer
> Hermann
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk9ZwawACgkQoYgNqgF2egoTHACbBb6vogFXiJdH8pPUiV7/msop
2/QAn3mkiSltkoradtmuhjxnND7c3lvy
=w4PR
-----END PGP SIGNATURE-----
