[GRASS-user] TIN (Linear interpolation) from points
Benjamin Ducke
benducke at fastmail.fm
Sat Mar 17 10:01:55 EDT 2012
v.geom no longer exists in the GRASS distribution,
because of licensing issues. See here
http://lists.osgeo.org/pipermail/grass-user/2002-April/006286.html
(first Google hit for "v.geom grass")
The new modules for triangulation are v.delaunay,
v.voronoi and v.hull.
Ben
On 03/17/2012 02:56 PM, Vincent Bain wrote:
> Hi,
> sorry if I misunderstand your needs but have a look at r.surf.nnbathy,
> it could do the job for a raster output. First you need to retrieve nn
> libs. More details on the author's web page :
> http://www.sieczka.org/programy_pl.html
> Yours,
> Vincent.
> Le samedi 17 mars 2012 à 04:30 -0700, TheGeographer a écrit :
>> In the past there was a module which created TINs from points as input in
>> GRASS, but now it is not longer supported:
>> http://www.grass-kr.org/html/v.geom.html
>> For me this part is very interesting: MaxMin-Height triangulation
>> But the last GRASS version which is supported is Version 5.4 .
>> I easily created a TIN with 3 points in QGIS in a couple of seconds. Is
>> there an possibility in GRASS GIS,too?
>> I don't understand why it is still not integrated into GRASS GIS (This
>> application is much older than QGIS?)
>> The possibility of automation in GRASS GIS via shellscript is the main
>> reason why i need GRASS.
>> The (Elevation-)TIN should look like this:
>> http://osgeo-org.1560.n6.nabble.com/file/n4627723/tin_qgis.jpg
>> After the TIN creation I want to use the r.contour module to get contours
>> out of the TIN.
>> Greetings
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/TIN-Linear-interpolation-from-points-tp4627723p4627723.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
