[GRASS-user] Re: Overcoming Error in v.in.e00
    Helmut Kudrnovsky
    hellik at web.de
    Tue Mar 20 18:34:26 EDT 2012
>   I'm trying to use postgres for all vector map attributes and have read
>everything in the on-line docs several times.
>   What I'm finding is that when I import a new map (such as the waterbody
>.e00 that started this thread) the attributes end up in a .dbf table rather
>than a new postgres table.
dbf seems to be the default database backend for this mapset.
what I would do:
- create a new mapset
- set sqlite/postgres as the default database backend for this mapset:
[http://grass.osgeo.org/grass64/manuals/html64_user/databaseintro.html
http://grass.osgeo.org/grass64/manuals/html64_user/db.connect.html]
db.connect - Prints/sets general DB connection for current mapset and exits.
- if you import a vector (v.in.ogr,v.in.e00,etc.), vector attribute data
should be then stored in the default database backend for this mapset.
AFAIK no need to manually edit ~/.grasslogin64, ~/.grassrc6, and ~/.grasswx6
etc.
AFAICT another "easy" way to create a mapset with i.e. sqlite as the
database backend for a mapset is to start a grass7-session and create a new
mapset.
in grass7 the default vector database backend is sqlite.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/Overcoming-Error-in-v-in-e00-tp4637344p4638616.html
Sent from the Grass - Users mailing list archive at Nabble.com.
