[GRASS-user] How Does GRASS Handle PostgreSQL Database Name
Change?
Rich Shepard
rshepard at appl-ecosys.com
Wed Mar 21 18:25:58 EDT 2012
On Wed, 21 Mar 2012, Daniel Lee wrote:
> I've also had trouble with using Postgres tables in GRASS and then
> changing them. If I deleted the tables in the past, it was always very
> difficult to be able to delete the corresponding vector maps. My only real
> positive experience in that regard has been to delete the mapset and start
> anew, but of course that's about as far from elegant as you can get. Sorry
> that I don't know more about the way GRASS interacts with Postgres and
> where the connection is stored.
Daniel,
I'm sure that the grass-postgres interface could use a lot of tuning, but
the developers are probably focused more on other aspects.
For one project, deleting a couple of locations/mapsets would be a hassle,
but do-able as a last resort. The other project has several dozen maps and
postgres tables and I'd hate to have to recreate them all.
What puzzles me is that db.connect -p shows the new database name, but
when I try to import an .e00 file or re-project the vector map, the GUI
crashes; if I do it on the command line, I still get the errors that caused
the GUI to leave.
Thanks,
Rich
