[GRASS-user] How Does GRASS Handle PostgreSQL Database Name
Change?
Maris Nartiss
maris.gis at gmail.com
Thu Mar 22 03:32:27 EDT 2012
Hello,
it seems that You are looking for v.db.connect, as You need to
reconnect existing vector data sets to a different database. (Or, if
You are careful, just edit MAPSET/vector/MYMAP/dbln file.)
As goes for a GUI crash, please, report it in the issue tracker, as
WXGUI shouldn't crash if DB connection information isn't correct.
Maris.
2012/3/22 Rich Shepard <rshepard at appl-ecosys.com>:
> On Wed, 21 Mar 2012, Daniel Lee wrote:
>> I've also had trouble with using Postgres tables in GRASS and then
>> changing them. If I deleted the tables in the past, it was always very
>> difficult to be able to delete the corresponding vector maps. My only real
>> positive experience in that regard has been to delete the mapset and start
>> anew, but of course that's about as far from elegant as you can get. Sorry
>> that I don't know more about the way GRASS interacts with Postgres and
>> where the connection is stored.
> Daniel,
> I'm sure that the grass-postgres interface could use a lot of tuning, but
> the developers are probably focused more on other aspects.
> For one project, deleting a couple of locations/mapsets would be a hassle,
> but do-able as a last resort. The other project has several dozen maps and
> postgres tables and I'd hate to have to recreate them all.
> What puzzles me is that db.connect -p shows the new database name, but
> when I try to import an .e00 file or re-project the vector map, the GUI
> crashes; if I do it on the command line, I still get the errors that caused
> the GUI to leave.
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
