[GRASS-user] NVIZ Seg Faults
Maris Nartiss maris.gis at gmail.com
Fri Mar 23 03:42:51 EDT 2012
Hello Rich,
with Your provided data it's not possible to tell if You can do something.
Things to check:
1) the size of Your computational region. On 32bit system You might
hit a memory limits.
2) check Your OpenGL system. Does glxinfo and glxgears work fine?
3) run nviz under gdb and generate backtrace. Still You might need to
recompile GRASS with --enable-debug to get also debug symbols for all
GRASS parts. --enable-debug is harmless and wouldn't interfere with
normal working with GRASS, it will only help to track down bugs.
Here are some notes I have made for myself on running nviz under gdb
and valgrind:
gdb $GISBASE/etc/nviz2.2/nviz
run -f "$GISBASE/etc/nviz2.2/scripts/nviz2.2_script"
elevation=elevation.dem at PERMANENT
valgrind $GISBASE/etc/nviz2.2/nviz -f
Maris.
2012. gada 23. marts 02:10 Rich Shepard <rshepard at appl-ecosys.com> rakstīja:
>  The raster map directory holds 2.4G of data. Trying to run nviz causes a
> seg fault after processing ~3%:
> GRASS 6.5.svn (Washington):~/grassdata > nviz elev=dem_basin
> Loading raster map <dem_basin at buckets>...
> Segmentation fault
>  Anything I can do to prevent this?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
