[GRASS-user] r.shaded.relief Output Question
Rich Shepard
rshepard at appl-ecosys.com
Fri Mar 23 14:31:19 EDT 2012
On Fri, 23 Mar 2012, Daniel Lee wrote:
> I can't imagine that resampling would reverse the DEM values though.
Me, neither.
> A glance at r.info would give you the answer to that - if the values are
> mostly negative, it should be a pretty good sign that you're either in
> Death Valley or inverted :P
| Type of Map: raster Number of Categories: 255
| Data Type: DCELL
| Rows: 2671
| Columns: 3216
| Total Cells: 8589936
| Projection: Lambert Conformal Conic
| N: 735780 S: 655650 Res: 30
| E: 2138580 W: 2042100 Res: 30
| Range of data: min = 561.412536621094 max = 2212.32543945312
| Data Source:
| dem_basin
| Source map NS res: 0.999982 EW res: 1.00002702
| Data Description:
| generated by r.resamp.stats
| Comments:
| r.resamp.stats input="dem_basin" output="dem10m.avg" method="average"
Looks normal to me.
> One thing to note with r.shaded.relief though is that it doesn't use the
> GRASS convention for solar azimuths.
That's what the manual page says.
> ... 235° would be ... from the southwest.
Yep. That's the way it usually works.
> When I look at your map (wish the resolution was a bit higher) it looks
> like the sun very well could be coming from that direction (I'm just using
> the rivers as orientation for relative height). Have you tried another
> angle, like taking a look at what the map looks like if the sun's shining
> from 180° (due south)?
Not yet. I try different altitude angles and moved to 225 degrees so far.
But, the map appears inverted to me.
Rich
