[GRASS-user] Re: Aster DEM
Stefan Sylla stefansylla at gmx.de
Sat Mar 24 00:20:25 EDT 2012
Hi Javier,
EGM96 (I guess somethin' like 'Earth Geodetic Model') refers to the
vertical datum. If
you only need relative height information (e.g. for watershed
analysis), you do not need
information retrieved from the vertical datum. However, if you need
absolute heights
(e.g. height above sea level), you should recalculate the height
values (substract EGM96
offset from Aster DEM heights) according to the region of your DEM.
Hope that helps
Stefan
Quoting "Javier García [via OSGeo.org]"
<ml-node+s1560n4650688h76 at n6.nabble.com>:
> Hi, I have a question that i hope you can help me.
> I want to use some aster Dem, but in specifications I read that
> aster Dem is using EGM96
> geoid . Do I have to do something special to use those DEM's?
> The zone that I work is WGS84 147N.
> Thanks in advance for the answer.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.n6.nabble.com/Aster-DEM-tp4650688p4650688.html
> To start a new topic under Grass - Users, email
> ml-node+s1560n3884509h27 at n6.nabble.com
> To unsubscribe from Grass - Users, visit
> http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3884509&code=c3RlZmFuc3lsbGFAZ214LmRlfDM4ODQ1MDl8LTExNTE4ODczMTc=
View this message in context: http://osgeo-org.1560.n6.nabble.com/Aster-DEM-tp4650688p4650804.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120323/6a5a173c/attachment.html
