[GRASS-user] Re: Aster DEM
Stefan Sylla
stefansylla at gmx.de
Sat Mar 24 00:29:26 EDT 2012
> The zone that I work is WGS84 147N.
Normally the Aster DEM comes with a WGS84 lat-long grid, so your
settings seem to be ok, except that you have a zone; there are no
zones for WGS84. Maybe your location is UTM zone 147N? Then the import
of the Aster DEM will not work. You have to set up a WGS84 location.
Or just do the following in your current loacation:
r.in.gdal in=aster.tif out=aster.dem location=aster
With that, r.in.gdal will create a new location corresponding to the
projection information of the Aster DEM.
Stefan
Quoting "Javier García [via OSGeo.org]"
<ml-node+s1560n4650688h76 at n6.nabble.com>:
> Hi, I have a question that i hope you can help me.
> I want to use some aster Dem, but in specifications I read that
> aster Dem is using EGM96
> geoid . Do I have to do something special to use those DEM's?
> Thanks in advance for the answer.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.n6.nabble.com/Aster-DEM-tp4650688p4650688.html
> To start a new topic under Grass - Users, email
> ml-node+s1560n3884509h27 at n6.nabble.com
> To unsubscribe from Grass - Users, visit
> http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3884509&code=c3RlZmFuc3lsbGFAZ214LmRlfDM4ODQ1MDl8LTExNTE4ODczMTc=
View this message in context: http://osgeo-org.1560.n6.nabble.com/Aster-DEM-tp4650688p4650811.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120323/9c47c38f/attachment.html
