[GRASS-user] Re: Aster DEM
Daniel Lee lee at isi-solutions.org
Sat Mar 24 06:50:53 EDT 2012
Don't forget that afterwards you'll have to reproject the raster using
r.proj into the old location.
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber:
Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses
des Deutchen Bundestages, sowie durch die Europäiache Union,
Zuwendungsgeber: Europäischer Sozialfonds. Zusätzliche Unterstützung erhält
ISIS von dem Entrepreneurship Cluster Mittelhessen, der Universität
Marburg, dem Laboratory for Climatology and Remote Sensing und dem GIS-Lab
Marburg.
On Mar 24, 2012 5:29 AM, "Stefan Sylla" <stefansylla at gmx.de> wrote:
> > The zone that I work is WGS84 147N.
> Normally the Aster DEM comes with a WGS84 lat-long grid, so your
> settings seem to be ok, except that you have a zone; there are no
> zones for WGS84. Maybe your location is UTM zone 147N? Then the import
> of the Aster DEM will not work. You have to set up a WGS84 location.
> Or just do the following in your current loacation:
> r.in.gdal in=aster.tif out=aster.dem location=aster
> With that, r.in.gdal will create a new location corresponding to the
> projection information of the Aster DEM.
> Stefan
> Quoting "Javier García [via OSGeo.org]"
> <[hidden email] <http://user/SendEmail.jtp?type=node&node=4650811&i=0>>:
> > Hi, I have a question that i hope you can help me.
> > I want to use some aster Dem, but in specifications I read that
> > aster Dem is using EGM96
> > geoid . Do I have to do something special to use those DEM's?
> > Thanks in advance for the answer.
> > grass-user mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4650811&i=1>
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> > If you reply to this email, your message will be added to the
> > discussion below:
> > http://osgeo-org.1560.n6.nabble.com/Aster-DEM-tp4650688p4650688.html
> > To start a new topic under Grass - Users, email
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4650811&i=2>
> > To unsubscribe from Grass - Users, visit
> View this message in context: Re: Aster DEM<http://osgeo-org.1560.n6.nabble.com/Aster-DEM-tp4650688p4650811.html>
> Sent from the Grass - Users mailing list archive<http://osgeo-org.1560.n6.nabble.com/Grass-Users-f3884509.html>at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120324/21d6d11d/attachment-0001.html
