[GRASS-user] About Flood, Erosion and hydrological modelling
Roberto Marzocchi roberto.marzocchi at gmail.com
Sat Mar 24 09:15:09 EDT 2012
The two modules developed by GFOSSERVICE do practically the same thing of
hec-geo-ras.
Concerning r.inund.fluv it use a different approach with an almost-2D
flooding model.
For any question about this command and for further developments we are
available.
Best regards,
Roberto
Il giorno 24/mar/2012 13:05, "Venkatesh Raghavan" <
raghavan a media.osaka-cu.ac.jp> ha scritto:
> Hi Wolf,
> HEC-GeoRAS is used to prepare data inputs for HEC-RAS.
> I do not see any need to modify GRASS to prepare such
> input. It would need developing some new modules (and wxGUI)
> using GRASS Libraries.
> BTW, today http://www.hec.usace.army.mil/ seems to be down.
> Best
> Venka
> On 2012/03/24 4:50, Wolf Bergenheim wrote:
>> Hi Venka,
>> That seems to an interesting thing. I find it especially interesting since
>> it's from the same people who originally developed GRASS. Perhaps they
>> would be willing to co-mentor. Anyways Venka, do you have any information
>> on how it works together with ARC? I mean would it be possible to get it
>> to
>> work with GRASS without modifying anything but GRASS?
>> --Wolf
>> On Fri, Mar 23, 2012 at 09:35, Venkatesh Raghavan<
>> raghavan a media.osaka-cu.ac.jp>  wrote:
>>  Dear All,
>>> Doing a bit of work with tram in Vietnam using HEC-RAS and
>>> HEC-GeoRAS. It would be nice to have a GRASS interface to
>>> HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
>>> Perhaps a project for some student or Google Summer of Code?
>>> HEC-RAS
>>> http://www.hec.usace.army.mil/****software/hec-ras/<http://www.hec.usace.army.mil/**software/hec-ras/>
>>> <http://**www.hec.usace.army.mil/**software/hec-ras/<http://www.hec.usace.army.mil/software/hec-ras/>
>>> HEC-GeoRAS
>>> http://www.hec.usace.army.mil/****software/hec-ras/hec-georas.****html<http://www.hec.usace.army.mil/**software/hec-ras/hec-georas.**html>
>>> <http://www.hec.usace.**army.mil/software/hec-ras/hec-**georas.html<http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html>
>>> I have also included some other modelling tools related to
>>> flood/hydrology, erosion etc. Perhaps you know most of it already.
>>> In future, it may be world considering
>>> how some of these models can be put to work together to
>>> bring out more comprehensive output of physical processes.
>>> For example there is already some work on integrating HEC-RAS with
>>> MODFLOW.
>>> https://publicwiki.deltares.****nl/display/OPENMI/Workshops+**
>>> on+integration+of+the+HEC-RAS+****and+MODFLOW+models+using+****OpenMI<
>>> https://publicwiki.**deltares.nl/display/OPENMI/**
>>> Workshops+on+integration+of+**the+HEC-RAS+and+MODFLOW+**
>>> models+using+OpenMI<https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI>
>>> Fully conservative coupling of HEC-RAS with MODFLOW to simulate
>>> stream–aquifer interactions in a drainage basin
>>> http://www.sciencedirect.com/****science/article/pii/****
>>> S0022169408000772<http://www.sciencedirect.com/**science/article/pii/**S0022169408000772>
>>> <http://www.**sciencedirect.com/science/**article/pii/S0022169408000772<http://www.sciencedirect.com/science/article/pii/S0022169408000772>
>>> Surface Water-Groundwater Software Coupling
>>> http://www.groundwater-**confe**rence.uci.edu/files/**<http://conference.uci.edu/files/**>
>>> Chapter4/2008_conf_Fenske,%****20J.pdf<http://www.**
>>> groundwater-conference.uci.**edu/files/Chapter4/2008_conf_**
>>> Fenske,%20J.pdf<http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf>
>>> Development of integrated MODFLOW HEC-RAS model using OpenMI
>>> http://code.google.com/p/****rasmodflow/<http://code.google.com/p/**rasmodflow/>
>>> <http://code.**google.com/p/rasmodflow/<http://code.google.com/p/rasmodflow/>
>>> Flood/Hydrological Modelling
>>> ICHARM, Japan
>>> http://www.icharm.pwri.go.jp/
>>> Integrated Flood Analysis System (IFAS)
>>> http://www.icharm.pwri.go.jp/****research/ifas/index.html<http://www.icharm.pwri.go.jp/**research/ifas/index.html>
>>> <http**://www.icharm.pwri.go.jp/**research/ifas/index.html<http://www.icharm.pwri.go.jp/research/ifas/index.html>
>>> BASINS (Better Assessment Science Integrating point&  Non-point Sources)
>>> http://water.epa.gov/scitech/****datait/models/basins/index.**cfm<http://water.epa.gov/scitech/**datait/models/basins/index.cfm>
>>> <http://water.epa.gov/**scitech/datait/models/basins/**index.cfm<http://water.epa.gov/scitech/datait/models/basins/index.cfm>
>>> Kinematic runoff and erosion model KINEROS
>>> http://www.tucson.ars.ag.gov/****kineros/<http://www.tucson.ars.ag.gov/**kineros/>
>>> <http://www.tucson.**ars.ag.gov/kineros/<http://www.tucson.ars.ag.gov/kineros/>
>>> GIS and Distributed Watershed Models II
>>> http://digitalcommons.unl.edu/****cgi/viewcontent.cgi?article=****<http://digitalcommons.unl.edu/**cgi/viewcontent.cgi?article=**>
>>> 1466&context=usdaarsfacpub&****sei-redir=1&referer=http%3A%**
>>> 2F%2Fwww.google.com%2Furl%****3Fsa%3Dt%26rct%3Dj%26q%3Dhec-****
>>> ras%2520grass%2520gis%****26source%3Dweb%26cd%3D6%26ved%****
>>> 3D0CEYQFjAF%26url%3Dhttp%253A%****252F%252Fdigitalcommons.unl.****
>>> edu%252Fcgi%252Fviewcontent.****cgi%253Farticle%253D1466%**
>>> 2526context%253Dusdaarsfacpub%****26ei%3DO31mT5j_H_**
>>> HsmAWtw4G5CA%**26usg%**
>>> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8****ZipR2A#search=%22hec-ras%**
>>> 20grass%20gis%22<http://**digitalcommons.unl.edu/cgi/**
>>> viewcontent.cgi?article=1466&**context=usdaarsfacpub&sei-**
>>> redir=1&referer=http%3A%2F%**2Fwww.google.com%2Furl%3Fsa%**
>>> 3Dt%26rct%3Dj%26q%3Dhec-ras%**2520grass%2520gis%26source%**
>>> 3Dweb%26cd%3D6%26ved%**3D0CEYQFjAF%26url%3Dhttp%253A%**
>>> 252F%252Fdigitalcommons.unl.**edu%252Fcgi%252Fviewcontent.**
>>> cgi%253Farticle%253D1466%**2526context%253Dusdaarsfacpub%**
>>> 26ei%3DO31mT5j_H_HsmAWtw4G5CA%**26usg%**3DAFQjCNEyfNWNrpn8XB73bGz8lAN8**
>>> ZipR2A#search=%22hec-ras%**20grass%20gis%22<http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22>
>>> Best
>>> Venka
>>> ______________________________****_________________
>>> grass-user mailing list
>>> grass-user a lists.osgeo.org
>>> http://lists.osgeo.org/****mailman/listinfo/grass-user<http://lists.osgeo.org/**mailman/listinfo/grass-user>
>>> <ht**tp://lists.osgeo.org/mailman/**listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
> ______________________________**_________________
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120324/d94d8e32/attachment.html
