[GRASS-user] About Flood, Erosion and hydrological modelling
Wolf Bergenheim wolf+grass at bergenheim.net
Sat Mar 24 10:03:55 EDT 2012
I thought that the name did sound familiar. Would you be willing to mentor
if there is a student interested in it? In that case you could post it to
the ideas page.
--Wolf
On Sat, Mar 24, 2012 at 14:15, Roberto Marzocchi <
roberto.marzocchi at gmail.com> wrote:
> The two modules developed by GFOSSERVICE do practically the same thing of
> hec-geo-ras.
> Concerning r.inund.fluv it use a different approach with an almost-2D
> flooding model.
> For any question about this command and for further developments we are
> available.
> Best regards,
> Roberto
> Il giorno 24/mar/2012 13:05, "Venkatesh Raghavan" <
> raghavan at media.osaka-cu.ac.jp> ha scritto:
>  Hi Wolf,
>> HEC-GeoRAS is used to prepare data inputs for HEC-RAS.
>> I do not see any need to modify GRASS to prepare such
>> input. It would need developing some new modules (and wxGUI)
>> using GRASS Libraries.
>> BTW, today http://www.hec.usace.army.mil/ seems to be down.
>> Best
>> Venka
>> On 2012/03/24 4:50, Wolf Bergenheim wrote:
>>> Hi Venka,
>>> That seems to an interesting thing. I find it especially interesting
>>> since
>>> it's from the same people who originally developed GRASS. Perhaps they
>>> would be willing to co-mentor. Anyways Venka, do you have any information
>>> on how it works together with ARC? I mean would it be possible to get it
>>> to
>>> work with GRASS without modifying anything but GRASS?
>>> --Wolf
>>> On Fri, Mar 23, 2012 at 09:35, Venkatesh Raghavan<
>>> raghavan at media.osaka-cu.ac.jp>  wrote:
>>>  Dear All,
>>>> Doing a bit of work with tram in Vietnam using HEC-RAS and
>>>> HEC-GeoRAS. It would be nice to have a GRASS interface to
>>>> HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
>>>> Perhaps a project for some student or Google Summer of Code?
>>>> HEC-RAS
>>>> http://www.hec.usace.army.mil/****software/hec-ras/<http://www.hec.usace.army.mil/**software/hec-ras/>
>>>> <http://**www.hec.usace.army.mil/**software/hec-ras/<http://www.hec.usace.army.mil/software/hec-ras/>
>>>> HEC-GeoRAS
>>>> http://www.hec.usace.army.mil/****software/hec-ras/hec-georas.****html<http://www.hec.usace.army.mil/**software/hec-ras/hec-georas.**html>
>>>> <http://www.hec.usace.**army.mil/software/hec-ras/hec-**georas.html<http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html>
>>>> I have also included some other modelling tools related to
>>>> flood/hydrology, erosion etc. Perhaps you know most of it already.
>>>> In future, it may be world considering
>>>> how some of these models can be put to work together to
>>>> bring out more comprehensive output of physical processes.
>>>> For example there is already some work on integrating HEC-RAS with
>>>> MODFLOW.
>>>> https://publicwiki.deltares.****nl/display/OPENMI/Workshops+**
>>>> on+integration+of+the+HEC-RAS+****and+MODFLOW+models+using+****OpenMI<
>>>> https://publicwiki.**deltares.nl/display/OPENMI/**
>>>> Workshops+on+integration+of+**the+HEC-RAS+and+MODFLOW+**
>>>> models+using+OpenMI<https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI>
>>>> Fully conservative coupling of HEC-RAS with MODFLOW to simulate
>>>> stream–aquifer interactions in a drainage basin
>>>> http://www.sciencedirect.com/****science/article/pii/****
>>>> S0022169408000772<http://www.sciencedirect.com/**science/article/pii/**S0022169408000772>
>>>> <http://www.**sciencedirect.com/science/**article/pii/S0022169408000772<http://www.sciencedirect.com/science/article/pii/S0022169408000772>
>>>> Surface Water-Groundwater Software Coupling
>>>> http://www.groundwater-**confe**rence.uci.edu/files/**<http://conference.uci.edu/files/**>
>>>> Chapter4/2008_conf_Fenske,%****20J.pdf<http://www.**
>>>> groundwater-conference.uci.**edu/files/Chapter4/2008_conf_**
>>>> Fenske,%20J.pdf<http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf>
>>>> Development of integrated MODFLOW HEC-RAS model using OpenMI
>>>> http://code.google.com/p/****rasmodflow/<http://code.google.com/p/**rasmodflow/>
>>>> <http://code.**google.com/p/rasmodflow/<http://code.google.com/p/rasmodflow/>
>>>> Flood/Hydrological Modelling
>>>> ICHARM, Japan
>>>> http://www.icharm.pwri.go.jp/
>>>> Integrated Flood Analysis System (IFAS)
>>>> http://www.icharm.pwri.go.jp/****research/ifas/index.html<http://www.icharm.pwri.go.jp/**research/ifas/index.html>
>>>> <http**://www.icharm.pwri.go.jp/**research/ifas/index.html<http://www.icharm.pwri.go.jp/research/ifas/index.html>
>>>> BASINS (Better Assessment Science Integrating point&  Non-point Sources)
>>>> http://water.epa.gov/scitech/****datait/models/basins/index.**cfm<http://water.epa.gov/scitech/**datait/models/basins/index.cfm>
>>>> <http://water.epa.gov/**scitech/datait/models/basins/**index.cfm<http://water.epa.gov/scitech/datait/models/basins/index.cfm>
>>>> Kinematic runoff and erosion model KINEROS
>>>> http://www.tucson.ars.ag.gov/****kineros/<http://www.tucson.ars.ag.gov/**kineros/>
>>>> <http://www.tucson.**ars.ag.gov/kineros/<http://www.tucson.ars.ag.gov/kineros/>
>>>> GIS and Distributed Watershed Models II
>>>> http://digitalcommons.unl.edu/****cgi/viewcontent.cgi?article=****<http://digitalcommons.unl.edu/**cgi/viewcontent.cgi?article=**>
>>>> 1466&context=usdaarsfacpub&****sei-redir=1&referer=http%3A%**
>>>> 2F%2Fwww.google.com%2Furl%****3Fsa%3Dt%26rct%3Dj%26q%3Dhec-****
>>>> ras%2520grass%2520gis%****26source%3Dweb%26cd%3D6%26ved%****
>>>> 3D0CEYQFjAF%26url%3Dhttp%253A%****252F%252Fdigitalcommons.unl.****
>>>> edu%252Fcgi%252Fviewcontent.****cgi%253Farticle%253D1466%**
>>>> 2526context%253Dusdaarsfacpub%****26ei%3DO31mT5j_H_**
>>>> HsmAWtw4G5CA%**26usg%**
>>>> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8****ZipR2A#search=%22hec-ras%**
>>>> 20grass%20gis%22<http://**digitalcommons.unl.edu/cgi/**
>>>> viewcontent.cgi?article=1466&**context=usdaarsfacpub&sei-**
>>>> redir=1&referer=http%3A%2F%**2Fwww.google.com%2Furl%3Fsa%**
>>>> 3Dt%26rct%3Dj%26q%3Dhec-ras%**2520grass%2520gis%26source%**
>>>> 3Dweb%26cd%3D6%26ved%**3D0CEYQFjAF%26url%3Dhttp%253A%**
>>>> 252F%252Fdigitalcommons.unl.**edu%252Fcgi%252Fviewcontent.**
>>>> cgi%253Farticle%253D1466%**2526context%253Dusdaarsfacpub%**
>>>> 26ei%3DO31mT5j_H_HsmAWtw4G5CA%**26usg%**3DAFQjCNEyfNWNrpn8XB73bGz8lAN8*
>>>> *ZipR2A#search=%22hec-ras%**20grass%20gis%22<http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22>
>>>> Best
>>>> Venka
>>>> ______________________________****_________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/****mailman/listinfo/grass-user<http://lists.osgeo.org/**mailman/listinfo/grass-user>
>>>> <ht**tp://lists.osgeo.org/mailman/**listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
>> ______________________________**_________________
>> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120324/527956d4/attachment-0001.html
