[GRASS-user] About Flood, Erosion and hydrological modelling
Roberto Marzocchi roberto.marzocchi at gmail.com
Mon Mar 26 03:37:52 EDT 2012
Yes, I am obviously willing. Do you intend the GRASS Soc Ideas 2012?
Reading the previous mails I didn't understand whether we are in time or
not.
R
Il giorno 24 marzo 2012 15:03, Wolf Bergenheim
<wolf+grass a bergenheim.net>ha scritto:
> I thought that the name did sound familiar. Would you be willing to mentor
> if there is a student interested in it? In that case you could post it to
> the ideas page.
> --Wolf
> On Sat, Mar 24, 2012 at 14:15, Roberto Marzocchi <
> roberto.marzocchi a gmail.com> wrote:
>> The two modules developed by GFOSSERVICE do practically the same thing of
>> hec-geo-ras.
>> Concerning r.inund.fluv it use a different approach with an almost-2D
>> flooding model.
>> For any question about this command and for further developments we are
>> available.
>> Best regards,
>> Roberto
>> Il giorno 24/mar/2012 13:05, "Venkatesh Raghavan" <
>> raghavan a media.osaka-cu.ac.jp> ha scritto:
>>  Hi Wolf,
>>> HEC-GeoRAS is used to prepare data inputs for HEC-RAS.
>>> I do not see any need to modify GRASS to prepare such
>>> input. It would need developing some new modules (and wxGUI)
>>> using GRASS Libraries.
>>> BTW, today http://www.hec.usace.army.mil/ seems to be down.
>>> Best
>>> Venka
>>> On 2012/03/24 4:50, Wolf Bergenheim wrote:
>>>> Hi Venka,
>>>> That seems to an interesting thing. I find it especially interesting
>>>> since
>>>> it's from the same people who originally developed GRASS. Perhaps they
>>>> would be willing to co-mentor. Anyways Venka, do you have any
>>>> information
>>>> on how it works together with ARC? I mean would it be possible to get
>>>> it to
>>>> work with GRASS without modifying anything but GRASS?
>>>> --Wolf
>>>> On Fri, Mar 23, 2012 at 09:35, Venkatesh Raghavan<
>>>> raghavan a media.osaka-cu.ac.jp>  wrote:
>>>>  Dear All,
>>>>> Doing a bit of work with tram in Vietnam using HEC-RAS and
>>>>> HEC-GeoRAS. It would be nice to have a GRASS interface to
>>>>> HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
>>>>> Perhaps a project for some student or Google Summer of Code?
>>>>> HEC-RAS
>>>>> http://www.hec.usace.army.mil/****software/hec-ras/<http://www.hec.usace.army.mil/**software/hec-ras/>
>>>>> <http://**www.hec.usace.army.mil/**software/hec-ras/<http://www.hec.usace.army.mil/software/hec-ras/>
>>>>> HEC-GeoRAS
>>>>> http://www.hec.usace.army.mil/****software/hec-ras/hec-georas.****html<http://www.hec.usace.army.mil/**software/hec-ras/hec-georas.**html>
>>>>> <http://www.hec.usace.**army.mil/software/hec-ras/hec-**georas.html<http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html>
>>>>> I have also included some other modelling tools related to
>>>>> flood/hydrology, erosion etc. Perhaps you know most of it already.
>>>>> In future, it may be world considering
>>>>> how some of these models can be put to work together to
>>>>> bring out more comprehensive output of physical processes.
>>>>> For example there is already some work on integrating HEC-RAS with
>>>>> MODFLOW.
>>>>> https://publicwiki.deltares.****nl/display/OPENMI/Workshops+**
>>>>> on+integration+of+the+HEC-RAS+****and+MODFLOW+models+using+****OpenMI<
>>>>> https://publicwiki.**deltares.nl/display/OPENMI/**
>>>>> Workshops+on+integration+of+**the+HEC-RAS+and+MODFLOW+**
>>>>> models+using+OpenMI<https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI>
>>>>> Fully conservative coupling of HEC-RAS with MODFLOW to simulate
>>>>> stream–aquifer interactions in a drainage basin
>>>>> http://www.sciencedirect.com/****science/article/pii/****
>>>>> S0022169408000772<http://www.sciencedirect.com/**science/article/pii/**S0022169408000772>
>>>>> <http://www.**sciencedirect.com/science/**
>>>>> article/pii/S0022169408000772<http://www.sciencedirect.com/science/article/pii/S0022169408000772>
>>>>> Surface Water-Groundwater Software Coupling
>>>>> http://www.groundwater-**confe**rence.uci.edu/files/**<http://conference.uci.edu/files/**>
>>>>> Chapter4/2008_conf_Fenske,%****20J.pdf<http://www.**
>>>>> groundwater-conference.uci.**edu/files/Chapter4/2008_conf_**
>>>>> Fenske,%20J.pdf<http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf>
>>>>> Development of integrated MODFLOW HEC-RAS model using OpenMI
>>>>> http://code.google.com/p/****rasmodflow/<http://code.google.com/p/**rasmodflow/>
>>>>> <http://code.**google.com/p/rasmodflow/<http://code.google.com/p/rasmodflow/>
>>>>> Flood/Hydrological Modelling
>>>>> ICHARM, Japan
>>>>> http://www.icharm.pwri.go.jp/
>>>>> Integrated Flood Analysis System (IFAS)
>>>>> http://www.icharm.pwri.go.jp/****research/ifas/index.html<http://www.icharm.pwri.go.jp/**research/ifas/index.html>
>>>>> <http**://www.icharm.pwri.go.jp/**research/ifas/index.html<http://www.icharm.pwri.go.jp/research/ifas/index.html>
>>>>> BASINS (Better Assessment Science Integrating point&  Non-point
>>>>> Sources)
>>>>> http://water.epa.gov/scitech/****datait/models/basins/index.**cfm<http://water.epa.gov/scitech/**datait/models/basins/index.cfm>
>>>>> <http://water.epa.gov/**scitech/datait/models/basins/**index.cfm<http://water.epa.gov/scitech/datait/models/basins/index.cfm>
>>>>> Kinematic runoff and erosion model KINEROS
>>>>> http://www.tucson.ars.ag.gov/****kineros/<http://www.tucson.ars.ag.gov/**kineros/>
>>>>> <http://www.tucson.**ars.ag.gov/kineros/<http://www.tucson.ars.ag.gov/kineros/>
>>>>> GIS and Distributed Watershed Models II
>>>>> http://digitalcommons.unl.edu/****cgi/viewcontent.cgi?article=****<http://digitalcommons.unl.edu/**cgi/viewcontent.cgi?article=**>
>>>>> 1466&context=usdaarsfacpub&****sei-redir=1&referer=http%3A%**
>>>>> 2F%2Fwww.google.com%2Furl%****3Fsa%3Dt%26rct%3Dj%26q%3Dhec-****
>>>>> ras%2520grass%2520gis%****26source%3Dweb%26cd%3D6%26ved%****
>>>>> 3D0CEYQFjAF%26url%3Dhttp%253A%****252F%252Fdigitalcommons.unl.****
>>>>> edu%252Fcgi%252Fviewcontent.****cgi%253Farticle%253D1466%**
>>>>> 2526context%253Dusdaarsfacpub%****26ei%3DO31mT5j_H_**
>>>>> HsmAWtw4G5CA%**26usg%**
>>>>> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8****ZipR2A#search=%22hec-ras%**
>>>>> 20grass%20gis%22<http://**digitalcommons.unl.edu/cgi/**
>>>>> viewcontent.cgi?article=1466&**context=usdaarsfacpub&sei-**
>>>>> redir=1&referer=http%3A%2F%**2Fwww.google.com%2Furl%3Fsa%**
>>>>> 3Dt%26rct%3Dj%26q%3Dhec-ras%**2520grass%2520gis%26source%**
>>>>> 3Dweb%26cd%3D6%26ved%**3D0CEYQFjAF%26url%3Dhttp%253A%**
>>>>> 252F%252Fdigitalcommons.unl.**edu%252Fcgi%252Fviewcontent.**
>>>>> cgi%253Farticle%253D1466%**2526context%253Dusdaarsfacpub%**
>>>>> 26ei%3DO31mT5j_H_HsmAWtw4G5CA%**26usg%**3DAFQjCNEyfNWNrpn8XB73bGz8lAN8
>>>>> **ZipR2A#search=%22hec-ras%**20grass%20gis%22<http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22>
>>>>> Best
>>>>> Venka
>>>>> ______________________________****_________________
>>>>> grass-user mailing list
>>>>> grass-user a lists.osgeo.org
>>>>> http://lists.osgeo.org/****mailman/listinfo/grass-user<http://lists.osgeo.org/**mailman/listinfo/grass-user>
>>>>> <ht**tp://lists.osgeo.org/mailman/**listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
>>> ______________________________**_________________
>>> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120326/cbc0dba6/attachment.html
