[GRASS-user] About Flood, Erosion and hydrological modelling
Wolf Bergenheim wolf+grass at bergenheim.net
Mon Mar 26 04:34:23 EDT 2012
Hello,
Yes I meant the GRASS Soc Ideas 2012 (
http://grass.osgeo.org/wiki/GRASS_SoC_Ideas_2012) Student's can start
submitting proposals in 10 hours, so sure, we can and should still add
ideas! The deadline for student proposals is April 6th
Here is the schedule:
http://www.google-melange.com/gsoc/events/google/gsoc2012
You should also apply to become a mentor for osgeo in
http://www.google-melange.com/ and read the mentoring guidbook:
http://www.booki.cc/gsoc-mentoring/ (or at least know where it is), and
send a hello + intro on soc at lists.osgeo.org
--Wolf
On Mon, Mar 26, 2012 at 09:37, Roberto Marzocchi <
roberto.marzocchi at gmail.com> wrote:
> Yes, I am obviously willing. Do you intend the GRASS Soc Ideas 2012?
> Reading the previous mails I didn't understand whether we are in time or
> not.
> R
> Il giorno 24 marzo 2012 15:03, Wolf Bergenheim <wolf+grass at bergenheim.net>ha scritto:
> I thought that the name did sound familiar. Would you be willing to mentor
>> if there is a student interested in it? In that case you could post it to
>> the ideas page.
>> --Wolf
>> On Sat, Mar 24, 2012 at 14:15, Roberto Marzocchi <
>>> The two modules developed by GFOSSERVICE do practically the same thing
>>> of hec-geo-ras.
>>> Concerning r.inund.fluv it use a different approach with an almost-2D
>>> flooding model.
>>> For any question about this command and for further developments we are
>>> available.
>>> Best regards,
>>> Roberto
>>> Il giorno 24/mar/2012 13:05, "Venkatesh Raghavan" <
>>> raghavan at media.osaka-cu.ac.jp> ha scritto:
>>>  Hi Wolf,
>>>> HEC-GeoRAS is used to prepare data inputs for HEC-RAS.
>>>> I do not see any need to modify GRASS to prepare such
>>>> input. It would need developing some new modules (and wxGUI)
>>>> using GRASS Libraries.
>>>> BTW, today http://www.hec.usace.army.mil/ seems to be down.
>>>> Best
>>>> Venka
>>>> On 2012/03/24 4:50, Wolf Bergenheim wrote:
>>>>> Hi Venka,
>>>>> That seems to an interesting thing. I find it especially interesting
>>>>> since
>>>>> it's from the same people who originally developed GRASS. Perhaps they
>>>>> would be willing to co-mentor. Anyways Venka, do you have any
>>>>> information
>>>>> on how it works together with ARC? I mean would it be possible to get
>>>>> it to
>>>>> work with GRASS without modifying anything but GRASS?
>>>>> --Wolf
>>>>> On Fri, Mar 23, 2012 at 09:35, Venkatesh Raghavan<
>>>>> raghavan at media.osaka-cu.ac.jp>  wrote:
>>>>>  Dear All,
>>>>>> Doing a bit of work with tram in Vietnam using HEC-RAS and
>>>>>> HEC-GeoRAS. It would be nice to have a GRASS interface to
>>>>>> HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
>>>>>> Perhaps a project for some student or Google Summer of Code?
>>>>>> HEC-RAS
>>>>>> http://www.hec.usace.army.mil/****software/hec-ras/<http://www.hec.usace.army.mil/**software/hec-ras/>
>>>>>> <http://**www.hec.usace.army.mil/**software/hec-ras/<http://www.hec.usace.army.mil/software/hec-ras/>
>>>>>> HEC-GeoRAS
>>>>>> http://www.hec.usace.army.mil/****software/hec-ras/hec-georas.**
>>>>>> **html<http://www.hec.usace.army.mil/**software/hec-ras/hec-georas.**html>
>>>>>> <http://www.hec.usace.**army.mil/software/hec-ras/hec-**georas.html<http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html>
>>>>>> I have also included some other modelling tools related to
>>>>>> flood/hydrology, erosion etc. Perhaps you know most of it already.
>>>>>> In future, it may be world considering
>>>>>> how some of these models can be put to work together to
>>>>>> bring out more comprehensive output of physical processes.
>>>>>> For example there is already some work on integrating HEC-RAS with
>>>>>> MODFLOW.
>>>>>> https://publicwiki.deltares.****nl/display/OPENMI/Workshops+**
>>>>>> on+integration+of+the+HEC-RAS+****and+MODFLOW+models+using+****
>>>>>> OpenMI<https://publicwiki.**deltares.nl/display/OPENMI/**
>>>>>> Workshops+on+integration+of+**the+HEC-RAS+and+MODFLOW+**
>>>>>> models+using+OpenMI<https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI>
>>>>>> Fully conservative coupling of HEC-RAS with MODFLOW to simulate
>>>>>> stream–aquifer interactions in a drainage basin
>>>>>> http://www.sciencedirect.com/****science/article/pii/****
>>>>>> S0022169408000772<http://www.sciencedirect.com/**science/article/pii/**S0022169408000772>
>>>>>> <http://www.**sciencedirect.com/science/**
>>>>>> article/pii/S0022169408000772<http://www.sciencedirect.com/science/article/pii/S0022169408000772>
>>>>>> Surface Water-Groundwater Software Coupling
>>>>>> http://www.groundwater-**confe**rence.uci.edu/files/**<http://conference.uci.edu/files/**>
>>>>>> Chapter4/2008_conf_Fenske,%****20J.pdf<http://www.**
>>>>>> groundwater-conference.uci.**edu/files/Chapter4/2008_conf_**
>>>>>> Fenske,%20J.pdf<http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf>
>>>>>> Development of integrated MODFLOW HEC-RAS model using OpenMI
>>>>>> http://code.google.com/p/****rasmodflow/<http://code.google.com/p/**rasmodflow/>
>>>>>> <http://code.**google.com/p/rasmodflow/<http://code.google.com/p/rasmodflow/>
>>>>>> Flood/Hydrological Modelling
>>>>>> ICHARM, Japan
>>>>>> http://www.icharm.pwri.go.jp/
>>>>>> Integrated Flood Analysis System (IFAS)
>>>>>> http://www.icharm.pwri.go.jp/****research/ifas/index.html<http://www.icharm.pwri.go.jp/**research/ifas/index.html>
>>>>>> <http**://www.icharm.pwri.go.jp/**research/ifas/index.html<http://www.icharm.pwri.go.jp/research/ifas/index.html>
>>>>>> BASINS (Better Assessment Science Integrating point&  Non-point
>>>>>> Sources)
>>>>>> http://water.epa.gov/scitech/****datait/models/basins/index.**cfm<http://water.epa.gov/scitech/**datait/models/basins/index.cfm>
>>>>>> <http://water.epa.gov/**scitech/datait/models/basins/**index.cfm<http://water.epa.gov/scitech/datait/models/basins/index.cfm>
>>>>>> Kinematic runoff and erosion model KINEROS
>>>>>> http://www.tucson.ars.ag.gov/****kineros/<http://www.tucson.ars.ag.gov/**kineros/>
>>>>>> <http://www.tucson.**ars.ag.gov/kineros/<http://www.tucson.ars.ag.gov/kineros/>
>>>>>> GIS and Distributed Watershed Models II
>>>>>> http://digitalcommons.unl.edu/****cgi/viewcontent.cgi?article=****<http://digitalcommons.unl.edu/**cgi/viewcontent.cgi?article=**>
>>>>>> 1466&context=usdaarsfacpub&****sei-redir=1&referer=http%3A%**
>>>>>> 2F%2Fwww.google.com%2Furl%****3Fsa%3Dt%26rct%3Dj%26q%3Dhec-****
>>>>>> ras%2520grass%2520gis%****26source%3Dweb%26cd%3D6%26ved%****
>>>>>> 3D0CEYQFjAF%26url%3Dhttp%253A%****252F%252Fdigitalcommons.unl.****
>>>>>> edu%252Fcgi%252Fviewcontent.****cgi%253Farticle%253D1466%**
>>>>>> 2526context%253Dusdaarsfacpub%****26ei%3DO31mT5j_H_**
>>>>>> HsmAWtw4G5CA%**26usg%**
>>>>>> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8****ZipR2A#search=%22hec-ras%**
>>>>>> 20grass%20gis%22<http://**digitalcommons.unl.edu/cgi/**
>>>>>> viewcontent.cgi?article=1466&**context=usdaarsfacpub&sei-**
>>>>>> redir=1&referer=http%3A%2F%**2Fwww.google.com%2Furl%3Fsa%**
>>>>>> 3Dt%26rct%3Dj%26q%3Dhec-ras%**2520grass%2520gis%26source%**
>>>>>> 3Dweb%26cd%3D6%26ved%**3D0CEYQFjAF%26url%3Dhttp%253A%**
>>>>>> 252F%252Fdigitalcommons.unl.**edu%252Fcgi%252Fviewcontent.**
>>>>>> cgi%253Farticle%253D1466%**2526context%253Dusdaarsfacpub%**
>>>>>> 26ei%3DO31mT5j_H_HsmAWtw4G5CA%**26usg%**
>>>>>> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8**ZipR2A#search=%22hec-ras%**
>>>>>> 20grass%20gis%22<http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22>
>>>>>> Best
>>>>>> Venka
>>>>>> ______________________________****_________________
>>>>>> grass-user mailing list
>>>>>> grass-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/****mailman/listinfo/grass-user<http://lists.osgeo.org/**mailman/listinfo/grass-user>
>>>>>> <ht**tp://lists.osgeo.org/mailman/**listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
>>>> ______________________________**_________________
>>>> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120326/d0531a00/attachment-0001.html
