[GRASS-user] r.sun on a small portion of my region
    Daniel Lee
    lee at isi-solutions.org
    Sat Mar 24 15:36:38 EDT 2012
Hi  Andrea,
I'd either buffer the garden you're trying to analyze by about 500m or so
and then run the analysis on the buffer area or set the regional settings
to cover a smaller area of your DSM. I believe r.sun uses the computational
region you set. For such a small area I honestly wouldn't bother with
horizon maps. You were probably thinking of using the mode of r.horizon
that makes horizons for a specific point, but that's not the type that
r.sun uses as input. It uses a number of rasters. For such a small area,
though, it won't make a difference - you should just make slope and aspect
maps and then use those, together with the surface model, as inputs for
r.sun. Hope that helps!
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber:
Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses
des Deutschen Bundestages, sowie durch die Europäische Union,
Zuwendungsgeber: Europäischer Sozialfonds.
Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster
Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and
Remote Sensing und dem GIS-Lab Marburg.
Am 24. März 2012 13:59 schrieb sanzoghenzo <andrea.ghensi at gmail.com>:
> Hi all,
> I'm trying to analyze the sun radiation of a garden in my town (
> http://g.co/maps/p56kn )
> I got LIDAR DTM with 1mx1m resolution from the local administration.
> To get in account the shadowing effect of the terrain I have to set a big
> region, and r.sun calculates the radiation of all the region.
> I red about r.horizon and the bufferzone option, so I could calculate the
> horizon line first. But from what I understood r.horizon adds inaccuracy to
> the calculation.
> Is there something like bufferzone in r.sun? or should I go with r.horizon
> and accept a less accurate result?
> Regards,
> Andrea
> http://osgeo-org.1560.n6.nabble.com/r-sun-on-a-small-portion-of-my-region-tp4651554p4651554.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120324/38d7fae3/attachment.html
