[GRASS-user] Re: r.sun on a small portion of my region
    sanzoghenzo
    andrea.ghensi at gmail.com
    Mon Mar 26 13:40:16 EDT 2012
Hi Daniel, thanks for the help.
I did the analysis without horizons and restricting the region to a small area.
Maybe the results are not so accurate (at 21 of december it says I got 10 hour of sun, but I think the mountain that sits at 3km in western direction reduces significantly the hours of sun) but for now I can live with that.
It would be great to add a r.horizon-like-bufferzone option in r.sun!
Cheers
Andrea Ghensi
Non controllo la posta spesso, se è urgente usa questo link: - https://awayfind.com/aghensi
Il giorno sabato 24 marzo 2012, alle ore 19.37, Daniel Lee [via OSGeo.org (http://OSGeo.org)] ha scritto:
> Hi Andrea,
> I'd either buffer the garden you're trying to analyze by about 500m or so and then run the analysis on the buffer area or set the regional settings to cover a smaller area of your DSM. I believe r.sun uses the computational region you set. For such a small area I honestly wouldn't bother with horizon maps. You were probably thinking of using the mode of r.horizon that makes horizons for a specific point, but that's not the type that r.sun uses as input. It uses a number of rasters. For such a small area, though, it won't make a difference - you should just make slope and aspect maps and then use those, together with the surface model, as inputs for r.sun. Hope that helps!
> Daniel
> B.Sc. Daniel Lee
> Geschäftsführung für Forschung und Entwicklung
> ISIS - International Solar Information Solutions GbR
> Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
> Deutschhausstr. 10
> 35037 Marburg
> Festnetz: +49 6421 379 6256
> Mobil: +49 176 6127 7269
> E-Mail: [hidden email] (/user/SendEmail.jtp?type=node&node=4652234&i=0)
> Web: http://www.isi-solutions.org (http://www.isi-solutions.org/)
> ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber: Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses des Deutschen Bundestages, sowie durch die Europäische Union, Zuwendungsgeber: Europäischer Sozialfonds.
> Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and Remote Sensing und dem GIS-Lab Marburg.
> Am 24. März 2012 13:59 schrieb sanzoghenzo <[hidden email] (/user/SendEmail.jtp?type=node&node=4652234&i=1)>:
> > Hi all,
> > I'm trying to analyze the sun radiation of a garden in my town (
> > http://g.co/maps/p56kn )
> > I got LIDAR DTM with 1mx1m resolution from the local administration.
> > To get in account the shadowing effect of the terrain I have to set a big
> > region, and r.sun calculates the radiation of all the region.
> > I red about r.horizon and the bufferzone option, so I could calculate the
> > horizon line first. But from what I understood r.horizon adds inaccuracy to
> > the calculation.
> > Is there something like bufferzone in r.sun? or should I go with r.horizon
> > and accept a less accurate result?
> > Regards,
> > Andrea
> > View this message in context: http://osgeo-org.1560.n6.nabble.com/r-sun-on-a-small-portion-of-my-region-tp4651554p4651554.html
> > Sent from the Grass - Users mailing list archive at Nabble.com (http://Nabble.com).
> > grass-user mailing list
> > [hidden email] (/user/SendEmail.jtp?type=node&node=4652234&i=2)
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> [hidden email] (/user/SendEmail.jtp?type=node&node=4652234&i=3)
> If you reply to this email, your message will be added to the discussion below: http://osgeo-org.1560.n6.nabble.com/r-sun-on-a-small-portion-of-my-region-tp4651554p4652234.html
> To unsubscribe from r.sun on a small portion of my region, click here (http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4651554&code=YW5kcmVhLmdoZW5zaUBnbWFpbC5jb218NDY1MTU1NHw2MDc3MTkwMjg=).
> NAML (http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml)
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-sun-on-a-small-portion-of-my-region-tp4651554p4657725.html
Sent from the Grass - Users mailing list archive at Nabble.com.
Un allegato HTML � stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120326/0f9f9ab1/attachment-0001.html
