[GRASS-user] Re: r.surf.nnbathy and nnbathy installation
Danny Luque Ramirez
dalura86 at googlemail.com
Mon Mar 26 04:10:20 EDT 2012
Hi Daniel,
no GRASS does not print messages at all.
You can specify your script folder with following command: g.gisenv
set="GRASS_ADDON_PATH=/path/to/your/addons"
So i added a test path called: home/danny/interpolation
To check if you added your path correctly you can use:g.gisenv
GRASS_ADDON_PATH
And GRASS shows me my location correctly.
I've downloaded my GRASS 6.4.1 via Ubuntu Repository.
No I don't have other scripts at the moment.
Danny
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-surf-nnbathy-and-nnbathy-installation-tp4649302p4655982.html
Sent from the Grass - Users mailing list archive at Nabble.com.
