[GRASS-user] Re: r.what.rast.buffer crash
    NicolaiK
    nicolaikaarsen at hotmail.com
    Mon Mar 26 08:59:08 EDT 2012
Thanks a lot for your quick reply!
The point data in vector format is only around 1200 observations, so it
shouldn't cause any problems, I guess. However, I tried creating a test
subset consisting of only 2 points. Again I get the same error. :(
I guess next step to try is to run it on Linux. I have been a bit reluctant
to do that since I've never used Linux before, but if it makes it work it'll
be worth it. Will keep you posted once I find out whether that solves the
problem.
Best,
Nicolai
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-what-rast-buffer-crash-tp4558773p4656779.html
Sent from the Grass - Users mailing list archive at Nabble.com.
