[GRASS-user] Grass GUI does not start (anymore) in MacOs
William Kyngesburye
woklist at kyngchaos.com
Tue Mar 27 09:11:55 EDT 2012
Hmm, this is becoming quite an issue on non-English systems, I don't know why it started. Python expects the locale to be in the form language.encoding. ie english is "en_US.UTF-8".
Normally the option in the Terminal to set this automatically takes care of this in the LANG variable, but Python checks LC_CTYPE and LC_ALL first and somehow one of those is getting set on non-english systems.
The fix is to set LC_ALL in your ~/.bash_profile like LANG is set for your language (turn on the "Set locale env variables on startup" option in the advanced Settings in Terminal Preferences, then check "env" in a Terminal).
Note: the Adobe Unit Types error is harmless noise, you just have a very old Photoshop installed.
On Mar 27, 2012, at 2:55 AM, jbogdani wrote:
> Hello,
> I've a problem with GRASS on Snow Leopard. I've used successfully GRASS in
> the past, but it does not start in the GUI mode anymore. I can use it throw
> QGIS anyway.
> Here is the error it produces on stratup:
> 2012-03-27 09:52:23.326 osascript[534:903] Error loading
> /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit
> Types: dlopen(/Library/ScriptingAdditions/Adobe Unit
> Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found.
> Did find:
> Types: no matching architecture in universal wrapper
> osascript: OpenScripting.framework - scripting addition
> "/Library/ScriptingAdditions/Adobe Unit Types.osax" declares no loadable
> handlers.
> Python 2.6.1 found.
> And then, after hitting RETURN:
> Traceback (most recent call last):
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
> line 894, in <module>
> GRASSStartUp = StartUp(0)
> File
> "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py",
> line 7981, in __init__
> File
> line 7555, in _BootstrapApp
> line 865, in OnInit
> StartUp = GRASSStartup()
> line 57, in __init__
> self.grassrc = self._readGisRC()
> line 393, in _readGisRC
> grassrc[key.strip()] = utils.DecodeString(val.strip())
> File
> "/Users/Shared/src/GRASS/grass-6.4.2-snow/dist.i386-apple-darwin11.3.0/etc/wxpython/gui_modules/utils.py",
> line 667, in DecodeString
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
> line 459, in getdefaultlocale
> return _parse_localename(localename)
> File
> line 391, in _parse_localename
> raise ValueError, 'unknown locale: %s' % localename
> ValueError: unknown locale: UTF-8
> Error in GUI startup. If necessary, please
> report this error to the GRASS developers.
> Switching to text mode now.
> Hit RETURN to continue...
> After this I can use GRASS only from terminal....
> Any help?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Grass-GUI-does-not-start-anymore-in-MacOs-tp4659784p4659784.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
