[GRASS-user] Grass GUI does not start (anymore) in MacOs
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Mar 27 09:16:51 EDT 2012
I forgot to add a bash_profile example:
export LC_ALL=en_US.UTF-8
substitute your language code for en_US.
On Mar 27, 2012, at 8:11 AM, William Kyngesburye wrote:
> Hmm, this is becoming quite an issue on non-English systems, I don't know why it started.  Python expects the locale to be in the form language.encoding.  ie english is "en_US.UTF-8".
> Normally the option in the Terminal to set this automatically takes care of this in the LANG variable, but Python checks LC_CTYPE and LC_ALL first and somehow one of those is getting set on non-english systems.
> The fix is to set LC_ALL in your ~/.bash_profile like LANG is set for your language (turn on the "Set locale env variables on startup" option in the advanced Settings in Terminal Preferences, then check "env" in a Terminal).
> Note: the Adobe Unit Types error is harmless noise, you just have a very old Photoshop installed.
> On Mar 27, 2012, at 2:55 AM, jbogdani wrote:
>> Hello,
>> I've a problem with GRASS on Snow Leopard. I've used successfully GRASS in
>> the past, but it does not start in the GUI mode anymore. I can use it throw
>> QGIS anyway.
>> Here is the error it produces on stratup:
>> 2012-03-27 09:52:23.326 osascript[534:903] Error loading
>> /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit
>> Types:  dlopen(/Library/ScriptingAdditions/Adobe Unit
>> Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found.
>> Did find:
>> Types: no matching architecture in universal wrapper
>> osascript: OpenScripting.framework - scripting addition
>> "/Library/ScriptingAdditions/Adobe Unit Types.osax" declares no loadable
>> handlers.
>> Python 2.6.1 found.
>> And then, after hitting RETURN:
>> Traceback (most recent call last):
>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
>> line 894, in <module>
>>   GRASSStartUp = StartUp(0)
>> File
>> "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py",
>> line 7981, in __init__
>> File
>> line 7555, in _BootstrapApp
>> line 865, in OnInit
>>   StartUp = GRASSStartup()
>> line 57, in __init__
>>   self.grassrc  = self._readGisRC()
>> line 393, in _readGisRC
>>   grassrc[key.strip()] = utils.DecodeString(val.strip())
>> File
>> "/Users/Shared/src/GRASS/grass-6.4.2-snow/dist.i386-apple-darwin11.3.0/etc/wxpython/gui_modules/utils.py",
>> line 667, in DecodeString
>> File
>> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
>> line 459, in getdefaultlocale
>>   return _parse_localename(localename)
>> File
>> line 391, in _parse_localename
>>   raise ValueError, 'unknown locale: %s' % localename
>> ValueError: unknown locale: UTF-8
>> Error in GUI startup. If necessary, please
>> report this error to the GRASS developers.
>> Switching to text mode now.
>> Hit RETURN to continue...
>> After this I can use GRASS only from terminal....
>> Any help?
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Grass-GUI-does-not-start-anymore-in-MacOs-tp4659784p4659784.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
