[GRASS-user] Grass GUI does not start (anymore) in MacOs
William Kyngesburye
woklist at kyngchaos.com
Tue Mar 27 19:33:00 EDT 2012
What changes? I have R installed, though I don't use it except to compile rgdal for distribution.
On Mar 27, 2012, at 9:15 AM, Ralf Schäfer wrote:
> Hello,
> I observed exactly the same problem on a Mac with 10.6.x of a student and we identified an R installation as the culprit, during which the student had done changes in the terminal...
> So I would think that the Terminal preferences were changed by some other installation rather than it would be a bug.
> Cheers
> Ralf
>> That's not it then. 10.6.8 here also.
>> Did you try turning on the Terminal pref to set the locale?
>> On Mar 27, 2012, at 8:50 AM, Julian Bogdani wrote:
>>> Mine is 10.6.8
>>> Julian
>>> http://bradypus.net
>>> On 27 Mar 2012, at 15:47 , William Kyngesburye wrote:
>>>> Huh. Well, I did some poking around on the 'net and it looks like it's a bug in OS X 10.6 Terminal (LC_CTYPE=UTF-8 is wrong). But it's working for me - maybe it was fixed in an update - what is your system version?
>>>> On Mar 27, 2012, at 8:27 AM, Julian Bogdani wrote:
>>>>> Hello and thank you for the help.
>>>>> I have an English system and checking with env I had correctly LC_CTYPE=UTF-8.
>>>>> Terminal preferences was correctly set.
>>>>> Adding export LC_ALL=en_US.UTF-8 did solve the problem.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
