[GRASS-user] Grass GUI does not start (anymore) in MacOs
Ralf Schäfer
senator at ecotoxicology.de
Wed Mar 28 02:21:56 EDT 2012
Can`t tell you exactly - we had a GIS/GRASS course and she was the only student having this problem. And when I fixed the Terminal language issue, she reported that she had never changed anything in Terminal except for some installation associated with R/X11.
However, I have these installed as well (and dozens of other students with Macs) without a problem.
Generally just wanted to make the point that it is probably not a bug but some user change in Terminal that leads to the problem...
Cheers
Ralf
Am 28.03.2012 um 01:33 schrieb William Kyngesburye:
> What changes? I have R installed, though I don't use it except to compile rgdal for distribution.
> On Mar 27, 2012, at 9:15 AM, Ralf Schäfer wrote:
>> Hello,
>> I observed exactly the same problem on a Mac with 10.6.x of a student and we identified an R installation as the culprit, during which the student had done changes in the terminal...
>> So I would think that the Terminal preferences were changed by some other installation rather than it would be a bug.
>> Cheers
>> Ralf
>>> That's not it then. 10.6.8 here also.
>>> Did you try turning on the Terminal pref to set the locale?
>>> On Mar 27, 2012, at 8:50 AM, Julian Bogdani wrote:
>>>> Mine is 10.6.8
>>>> Julian
>>>> http://bradypus.net
>>>> On 27 Mar 2012, at 15:47 , William Kyngesburye wrote:
>>>>> Huh. Well, I did some poking around on the 'net and it looks like it's a bug in OS X 10.6 Terminal (LC_CTYPE=UTF-8 is wrong). But it's working for me - maybe it was fixed in an update - what is your system version?
>>>>> On Mar 27, 2012, at 8:27 AM, Julian Bogdani wrote:
>>>>>> Hello and thank you for the help.
>>>>>> I have an English system and checking with env I had correctly LC_CTYPE=UTF-8.
>>>>>> Terminal preferences was correctly set.
>>>>>> Adding export LC_ALL=en_US.UTF-8 did solve the problem.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed robot?
> [Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
