[GRASS-user] Re: Grid Mismatch while importing with 6.4.1 and
6.4.2
Markus Metz
markus.metz.giswork at googlemail.com
Wed Mar 28 08:49:42 EDT 2012
On Wed, Mar 28, 2012 at 2:06 PM, <antonio.rocha at deimos.com.pt> wrote:
> Greetings
> Daniel lee suggested me that the problem might be the defined region. But,
> as far as I know, Defined region has no impact over importing data. This is
> true right?
Yes, r.in.gdal ignores the current region. The extents and resolution
as reported by gdalinfo for the original raster and r.info for the
imported raster must be identical.
Markus M
> Thanks
> Antonio
> Am 27. März 2012 11:52 schrieb António Rocha <antonio.rocha at deimos.com.pt>:
>> Greetings
>> I have imported a Raster image in GRASS 6.4.1 with r.in.gdal and now, when
>> I import the same raster (with 6.4.2) there is a grid mistmatch (more or
>> less a quarter pixel) from previous import to the current import. The image
>> is the same, the Location/Mapset also the only difference is the update of
>> GRASS. Is this expected?
>> Thanks
>> Antonio
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
