[GRASS-user] Re: Grid Mismatch while importing with 6.4.1 and
6.4.2
antonio.rocha at deimos.com.pt
Wed Mar 28 09:02:42 EDT 2012
Hello Markus
So, if the same image imported in different GRASS versions to the same
Location/Mapset, but it has a displacement of half pixel, it means that
it was a problem in earlier version of GRASS?
Thanks
Antonio
On Wed, 28 Mar 2012 14:49:42 +0200, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> On Wed, Mar 28, 2012 at 2:06 PM, <antonio.rocha at deimos.com.pt>
> wrote:
>> Greetings
>> Daniel lee suggested me that the problem might be the defined
>> region. But,
>> as far as I know, Defined region has no impact over importing data.
>> This is
>> true right?
> Yes, r.in.gdal ignores the current region. The extents and resolution
> as reported by gdalinfo for the original raster and r.info for the
> imported raster must be identical.
> Markus M
>> Thanks
>> Antonio
>> Am 27. März 2012 11:52 schrieb António
>> Rocha <antonio.rocha at deimos.com.pt>:
>>> Greetings
>>> I have imported a Raster image in GRASS 6.4.1 with r.in.gdal and
>>> now, when
>>> I import the same raster (with 6.4.2) there is a grid mistmatch
>>> (more or
>>> less a quarter pixel) from previous import to the current import.
>>> The image
>>> is the same, the Location/Mapset also the only difference is the
>>> update of
>>> GRASS. Is this expected?
>>> Thanks
>>> Antonio
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
